Mr2 Problem!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2006, 04:41 AM   #1 (permalink)
View mr2pimp's Photo Gallery
2nd Generation Mr2 Problem!!!!
Hello i own a 91 mr2 turbo with a 2nd gen 3sgte engine. I am having trouble getting my car to start properly. When i put the key in my ignition and turn it to start it keeps trying to start my engine and will not stop i have to unplug my negitive ground to get it to stop! then smoke comes from my engine bay! Any ideas on whats going on here? help would be great! thank you.
mr2pimp is offline   Reply With Quote
Old 09-27-2006, 11:38 AM   #2 (permalink)
View 430hpToy's Photo Gallery
so the starter keeps cranking even when you turn the key to the off position???
8. No commercial/business/website promotion in Signatures. The only URLs allowed in signatures are to your own car's personal website or another Autoforums.com website. No exceptions!
430hpToy is offline   Reply With Quote
Old 09-28-2006, 10:22 AM   #3 (permalink)
View celeritas's Photo Gallery
hmm ide see if the starter relay is ok and connected all the way ...or if you start it wth the key and it keeps turning over ..hmm it might be something to do with the ignition switch .
celeritas is offline   Reply With Quote
Old 09-28-2006, 05:06 PM   #4 (permalink)
I put my switch to the off position and take my key out of the ignition and it still trys to start my car and then i smell an electrical burning from the engine bay. I had my starter tested today and it tested Good. my ignition switch is acting kind of funny tho.
Old 09-28-2006, 05:21 PM   #5 (permalink)
hopefully this helps!
http://www.mr2-tech.com/bgb/mechanic...ing_system.htm
Old 09-28-2006, 05:41 PM   #6 (permalink)
k thank you ill keep u updated.
Old 09-28-2006, 10:05 PM   #7 (permalink)
i Removed my ignition switch and noticed that they spliced into the ST1 Wire on the harness and the AM1 Wire looks burnt pretty bad it was attatched to a wire that was burnt also and shattered in my hand it was so bad. Im hopeing this is my problem figuring its like 42.00 for a new ignition switch. Does anybody know if that could be my problem?
Old 09-28-2006, 10:35 PM   #8 (permalink)
2nd Generation Pics of Ignition Starter Switch!!!!!!!!!!!
Heres pics of the Ignition Starter Switch. I Beleive they use to have a Viper car alarm installed and uninstalled it! Would this make the starter keep starting and blow my 7.5 Ecu IG Fuse in the engine bay?
AM1 Wire Burnt.
ST1 Wire Contected to a splitter .
IG1 Wire Contected to a cut wire.
Heres a Pic of the ignition starter switch.
Old 09-28-2006, 11:45 PM   #9 (permalink)
Black 94t
View blackwidow94t's Photo Gallery
i would just make sure there are no extra hot wires going into your starter harness. if that doesnt work get a new ignition switch from auto zone or advanced auto, if it still doesnt work you know that the ignition switch isnt your problem and you can take it back.
blackwidow94t is offline   Reply With Quote
Old 09-28-2006, 11:48 PM   #10 (permalink)
i'd have to say there's a 98.7% chance that's your problem! LOL
those wires look pretty crispy!
Old 09-28-2006, 11:50 PM   #11 (permalink)
dude, that ign. switch needs to be replaced regardless! and if not the switch, at least the wires!!!
Old 09-29-2006, 12:49 AM   #12 (permalink)
Black 94t
that would be a good idea too
Old 09-29-2006, 06:51 PM   #13 (permalink)
Well i rewired the ignition switch and now im just getting a click sound and my starter isnt even starting and my ecu 7.5a fuse keeps blowing any idea's?
Old 09-29-2006, 09:35 PM   #14 (permalink)
View thesavage's Photo Gallery
Well . . . the clicking sound could be that of a dead battery. I dunno, but it happened to me a couple weeks ago on my 98 Saturn SL2 and I had to buy a whole new battery. Of course, it was the original battery that died.
Anyway, I guess what I'm trying to say is that it made this clicking sound, and that could be one of the things that is wrong. As for your fuse blowing, I have no idea about that.
thesavage is offline   Reply With Quote
Old 09-29-2006, 10:33 PM   #15 (permalink)
The battery is brand new and i am jumping the car trying to start it and all it does is drain everything and doesnt even start the starter.
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
12 volt Problem on 91 MR2 Mike@Fidanza Hardcore Tech and Competition 2 06-07-2005 07:20 PM
Mr2 Overboosting problem closmr2 MR2 Forum 8 05-04-2005 11:26 PM
1991 MR2 with a locked up engine problem grillface MR2 Forum 13 04-06-2005 05:47 PM
