diferent ct26's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2006, 01:22 PM   #1 (permalink)
tamalpro
View tamalpro's Photo Gallery
2nd Generation diferent ct26's
ive seen ct26 turbos that have one and two waste gate valves, and also ones that in the inducer side the neck its straith and somes are bottle neck, wich one its from wich car? cause i want to buy a 86-92 ct26, and on ebay it says its from a 86-92 but they are diferent betwen one sale and another and i dont know ho has the good one
tamalpro is offline   Reply With Quote
Old 10-01-2006, 09:28 PM   #2 (permalink)
Now with even more BOOST
View QuadCamSix's Photo Gallery
There are 3 different primary versions of the CT26.
The MR2 uses a twin entry housing with a double wastegate flapper.
A CT25A is used on the supra and has the same turbine and center section. The compressor wheel is larger and the turbine housing is a single entry type.
the CT20B is a ceramic turbo found on later model MR2's and celicas.
QuadCamSix is offline   Reply With Quote
Old 10-02-2006, 06:53 PM   #3 (permalink)
tamalpro
so can i put a ct25 in my mr2?
so thats wath i seen that i coul put a supra turbo an it woul be better because the bigger compresor wheel and bigger compresor inlet, is it a bolt on for my mr2? because my its twin entry and how will it afect no having the double flaper?
Old 10-04-2006, 05:30 PM   #4 (permalink)
Gameroom cash: $134355
well this is quite interesting..... is the center section on this the same as the other ct26's?
mainly i ask because i have an OLDER ct20 (from a non-us 3tgte) that at some point in the future would like to upgrade the intake wheel & housing to something a bit bigger....
i believe the center section is the same as the ct20 that came on the 22rte....
Old 10-08-2006, 02:24 PM   #5 (permalink)
tamalpro
no answer?
im still wating for an answer...nobody?
Old 10-08-2006, 03:34 PM   #6 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $249101
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
is your exhaust housing still good? if so you can swap the center section and compressor housing from a 7mgte motor and give yourself an upgrade.
google "stage 0 upgrade"
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 10-08-2006, 07:50 PM   #7 (permalink)
tamalpro
Thumbs up upgrade 0
hey thats exactly wat im doing, i bought the supra turbo, and want to put a bigger compresor, i think a 46 its good for wat ive heard, now im loking for a good shop to do it
Old 10-08-2006, 09:58 PM   #8 (permalink)
jdm 2nd gen ftw!
View nepopolus's Photo Gallery
dont buy a supra turbo..waste of money just send in your mr-2 turbo and have the comp. wheel replaced with a bigger trim this is what i did when i bought my jdm rear(turbo was chewed up on both sides) i had it board to a 50 trim and new exhaust wheels was 750$,so it will be less then that, pulls at 3000rpm and belive me it pulls ALOT harder..and you would have a brand new turbo basically
nepopolus is offline   Reply With Quote
Old 10-13-2006, 07:32 PM   #9 (permalink)
tamalpro
i already did
i did bougth the supra turbo, now i want to do the rebuild, but im not shure if if its worth to spend $300 extra for the bigger compresor wheel job, instead for the SIMPLE rebuild, imean, ihave a bigger turbo already,(with maybe 2 psi more capable) and it spools faster dosent it? ...dosent it?
Old 10-15-2006, 06:56 PM   #10 (permalink)
jdm 2nd gen ftw!
you dont need to get a bigger comp wheel i was just saying it dosent cost alot more and it is easy power if your getting a rebuild anyway and if you want to get a upgraded turbo you may not have to because this one i got can run up to 20 psi(as they said never tried) but if you want to leave it like it is you defintly wont have to worry about your turbo for a very long time
