not entirely sure what would be entailed for the auto setup..... i would actually assume it to be easier....
on the manuals... there are the 2 shift linkages.... basically, they are just moved from one side to the other (by drilling a very large hole then adding a seal) then using the appropriate shaft selector.....
for an auto... i guess you would just need to extend the cable and make a mounting bracket....
