speedometer stopped working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2006, 12:22 AM   #1 (permalink)
View stryker30's Photo Gallery
well my speedometer stoped working all of a sudden and the my miles stoped spinning . and yesterday its started working again and suddenly stopped. my friend told me it was probably the cable that links to the transmission or the one that goes in the back of the dashboard. i checked the tranny that wasnt it but i cant figure out how to remove the dash to check if it loose back there.
thankyou
stryker30 is offline   Reply With Quote
Old 10-09-2006, 11:30 AM   #2 (permalink)
View phreakgirl's Photo Gallery
thankyou
What generation of MR2 is this?
If its a first gen, changing that cable is a pain in the butt. But getting to it from the dash isn't too hard.
Remove the cover that goes over the gauges first (2-4 screws above the gauges going skyward)
Unscrew the gauge bezel (2 screws on either side of the steering wheel under wiper and headlight switches) pull it out. twords the steering wheel and maneuver it around and out.
Gauges are screwed down only on the left and right side, undo them (you can tell which ones hold it in) , pull it twords you a little, this should give you enough room to put your hand behind it and pop it out. I had a hard time the first time I took gauges out because I didn't know how the plug came undone, but you just squeeze the two tabs and twist and pull and it should come right out.
You might need to undo some plugs located at the top back of the gauges to get to the speedo but they're easy to unplug.
For the MK2 I think it's the same idea, cept bezel first, because there is no top trim. I'm not sure though because I never had to take one apart.
Hope I helped.
Click here for my webshots account. (Kingston 2006 Album)
phreakgirl is offline   Reply With Quote
Old 10-09-2006, 11:39 AM   #3 (permalink)
yeah im sorry its a 1991 mr2. thank you for the info, ill give it a try.
Old 10-09-2006, 02:25 PM   #4 (permalink)
View 430hpToy's Photo Gallery
check the cable at the trans end first! it's a lot easier! all you have to do is open the engine lid and look down at the trans towards the back!
8. No commercial/business/website promotion in Signatures. The only URLs allowed in signatures are to your own car's personal website or another Autoforums.com website. No exceptions!
430hpToy is offline   Reply With Quote
Old 10-10-2006, 02:25 AM   #5 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
yea check the one the trans. if its not loose... unscrew it. check the tip on the cable to see if its broken. then under the driver side in front of the rear tire... under the splash guard is where the two piece cable connects. check to see if they are loose or if the tip broke there. lastly check the input to the instrument cluster. cause its hard to get out cause the speedo cable keeps it from coming out far enough to disconnect everything behind it. gotta have small hands or the right angle. its a pain thats why i suggest working from the transaxle on forward.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 10-14-2006, 03:25 PM   #6 (permalink)
View meoggi's Photo Gallery
if you check it at the trans then you can just replace it from there. easiest way i did it to my first gen
meoggi is offline   Reply With Quote
Old 10-25-2006, 05:45 PM   #7 (permalink)
View oldmanfu's Photo Gallery
same problem guys
except my 91 turbo 5spd, i loosing the nut, but it won't come out. it wiggles around and has alots of play ,but won't come loose. any ideas
oldmanfu is offline   Reply With Quote
Old 10-26-2006, 07:14 PM   #8 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
Hmm
I think there are like 2 or 3 posts of this on the same forum page..... people should look at a couple of pages B4 posting a new topic... No I am not an admin.... I just thought I would give an idea so people aren't waitinf for their post to be answered... people don't usually wanna answer the same question twice
Zz_005_zZ is offline   Reply With Quote
Speedo stopped working! christian777 Archived Corolla threads 1 08-16-2006 12:04 PM
Airbag and Horn stopped working at the same time... jlostlen T-100 0 06-29-2006 06:52 PM
odometer not working redceli Celica Forum 3 05-24-2005 10:09 PM
power door locks just stopped working ?? TRD_kid Audio, Video, and Security - Tech 1 04-04-2004 01:14 PM
Passenger side window stopped working 92MR2 MR2 Forum 2 12-04-2003 02:36 PM
