MR2 4age internals - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2006, 02:10 PM   #1 (permalink)
View 4AC = AE71's Photo Gallery
Gen1 MR2 4age internals
i did a search alrdy and came up with nothing. i want to build this motor to maybe about 200, MAYBE. i wanna do these upgrades to the internals:
1. port and polish the head
2. knife edge the crankshaft
3. higher comp pistons
4. mild cams without doing under bucket shims
5. some really good connecting rods (shot pinned and H-beam)
now note that i'm not a pro at tuning but have done my fair share. if any body has any feedback on these upgrades weather it be PRO or CON. plz i need opioions on these gentlemen...
4AC = AE71 is offline   Reply With Quote
Old 10-14-2006, 03:14 PM   #2 (permalink)
View meoggi's Photo Gallery
well now that all sounds nice. but just remember do not get hyperutectic any thing. they will break. i gaurantee
meoggi is offline   Reply With Quote
Old 10-28-2006, 08:21 PM   #3 (permalink)
Grumpy, but good at it
View te51levin's Photo Gallery
I suggest you do a little research on other forums (club4ag, hachiroku.net, dorikaze, mr2oc) and learn more about the weak points and strength of a 4AGE. You've suggested some parts that will do absolutely nothing for power, and you've neglacted quite a few ideas that are necessary to make power.
Where does that 200bhp figure come from? It takes a hell of a lot more than bolt-ons to support that kind of output.
te51levin is offline   Reply With Quote
Old 10-28-2006, 11:27 PM   #4 (permalink)
MR2 Mk1 AW11
KensMR2Parts's Avatar
View KensMR2Parts's Photo Gallery
Gen1 MO Power
OK, you want 200 HP by:
1. port and polish the head ... porting works, but the bigger the ports the more cam you need and the higher up (RPM) you will need to run the engine ... smaller ports flow more air (higher velocity at lower engine speed) ... polishing is passe; you get more air flow with an air barrier (rougher than polished ports)
2. knife edge the crankshaft ... good for a short term use engine (racing) but very high maintenance
3. higher comp pistons ... good move toward more power ... higher octane fuel and valve clearance issues
4. mild cams without doing under bucket shims ... if you remove and reinstall the same cams, reshimming would be a good idea ... a must with cam replacement ... if your can handle the emissions issues; go big (radical) or don't go at all
5. some really good connecting rods (shot pinned and H-beam) ... a lesser concern with the 4AG engine ...
Do as
te51levin suggests and check those other sources ... also check Sports Car Club of America (www.scca.com) Formula Atlantic (they get tons out of the 4AG) ... remember; Speed Costs; How Fast Do You Want To Go? ... big power engines are made of unobtainium that sells for cubic money ... also, there is no substitute for cubic inches (except for turbos) ... Good Luck!
KensMR2Parts is offline   Reply With Quote
FS: 1991 Super White Toyota MR2 Turbo! *Lots Of Pics!* [Cyanide] Vehicles 7 01-14-2006 11:27 AM
MR2 Safety Product Thread. =-) MR2 specific safety products from safedrives.com Safe Drives Supporting Vendor Sales 8 10-17-2005 06:16 PM
Corrolla 4age distributorand Mr2 4age distributor cap ???? back fire? Corollenertia Archived Corolla threads 5 07-06-2005 10:56 PM
