A/C question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2006, 10:51 AM   #1 (permalink)
View skybandit's Photo Gallery
USA A/C question
Howdy all,my A/C never worked due to the fact that the pulley belt that goes to the compressor is not operational.What I mean to say is that the bolt that the pulley is attached to is snapped so I cant attach a belt to it. My question is,can you just get a new bolt for it and how would you swap the snapped bolt for the new?? Seems like you need a whole new pulley assembly but I dunno.....thanks ya'll.
skybandit is offline   Reply With Quote
Old 10-16-2006, 11:12 AM   #2 (permalink)
View phreakgirl's Photo Gallery
if the bolt is through a threaded hole i dont see why you couldnt just pull it out and put a new one in, or replace everything, i cant imagine it's too expensive with used parts.
Click here for my webshots account. (Kingston 2006 Album)
phreakgirl is offline   Reply With Quote
Old 10-16-2006, 09:55 PM   #3 (permalink)
RideMr2's Avatar
View RideMr2's Photo Gallery
A temporary fix?
1.) Emergency Belt.
Autozone used to sell them. These belts have a screw/bolt holding them together and can be adjusted to many different sizes easily.
91 MR2 5sfe
03 Grand Am 2.2L Ecotec
RideMr2 is offline   Reply With Quote
Old 10-17-2006, 07:07 PM   #4 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
its late in the season for A/C so a temp fix is not necessary.
now i'm having trouble comprehending the issue. no bolt holds a belt on. a bolt holds the pulley on, but A/C doesn't use a "pulley"... but the compression's magnetic clutch assembly. so if what you saying makes any sense like if the bolt is broke that hold the clutch on, that doesn't stop you from attaching belt since the idle pully holds the tensioner for the A/C belt. so you could attach one but you'd worry about the pulley flying off?
i dunno... take a picture... might help
tHa kNiGHt FaLL is offline   Reply With Quote
Question about A/C Filter..... Spud Archived Corolla threads 10 10-18-2006 04:16 PM
A/C and general maintenance question t3ch Supra Forum 4 10-17-2006 07:14 PM
93 pickup a/c question majorjayhawk 89-95 Toyota Pickup/Hilux 4 10-17-2006 07:12 PM
A/C Question - Low Pressure Port noteworthyone General Discussion 2 06-15-2005 11:42 AM
A question regarding A/C TOYOTA CARS Camry & Solara Lounge 14 06-10-2005 04:00 PM
