you wouldn't get shit from increasing spark..... toyota designed the ignition system to burn all the fuel in the chamber. a stock ignition system can handle more than it puts or anyways. you'd be using all you reserve all the time and you'd have no dwell and your coil would wear faster. without more fuel to burn more spark is pointless.
a cam increases air in and air out.
bigger cam meaning duration, slope, and valve overlap = more air in and more out.
an engine is a giant vacuum... it sucks massive amount of air in... and pushes massive amount out. you want performance you increases the amount of air in each intake stroke and match it with the amount leaving. then be able to speed up that process using more fuel and more spark which is needed when more air is being used.
i said if you do it... do it all and at the same time. thats why kids who thinks because they are on a budget they'll do one thing at a time and get to all of it down the road but end up having all kinds of ignition or fuel issues. too much fuel can cause detonation... wrong spark timing or burn angles can cause preignition... all bad for the motor... do it all at once and make sure all the fuel gets burned at the right time.
