code scanner info - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2006, 11:53 PM   #1 (permalink)
View stryker30's Photo Gallery
code scanner info
im looking into buying a car code scanner for my 1991 toyota mr2 2.2
what do u guys recomend and how much do they go for. thank you
stryker30 is offline   Reply With Quote
Old 10-21-2006, 01:24 PM   #2 (permalink)
View OEMonkey's Photo Gallery
You don't need a scanner or any special tool if you're just trying to retrieve trouble codes. All you need is a jumper wire or a what most people use; a paperclip.
OEMonkey is offline   Reply With Quote
Old 10-21-2006, 02:22 PM   #3 (permalink)
View phreakgirl's Photo Gallery
yeah, that;s true. you don't need to buy one, you just use the paperclip and start counting, and then the repair manual should tell you what number means what
Click here for my webshots account. (Kingston 2006 Album)
phreakgirl is offline   Reply With Quote
Old 10-21-2006, 06:51 PM   #4 (permalink)
wat do you mean paperclip and start counting?????
Old 10-22-2006, 05:39 PM   #5 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
your looking for a generic.... soltice / snap on scan tool. you could by one for about 500.00 but you have to by all the individual software for the cars you want to test. these tools are good for OBI and OBII.
now the 91 is a OBI generation car
its called On Board Diagnostic I.
OBI you can hook up a scan tool to pull codes... but you don't have to. you can go to the small diagnostic link in the p/s rear engine bay and jump two pins... not sure which ones. and your check engine light will start to flash. you have to count the flashes and look up the code meaning.
so i suggest if its just for your car... leave it alone. but if you plan on using it for a proffesional use. its not a bad investment
tHa kNiGHt FaLL is offline   Reply With Quote
94 Camry Check Engine Light Code: 71 Check EGR Valve laksh99 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-29-2011 07:52 AM
EVAP Code PO446 rooneyap 4Runner Lounge 10 11-19-2009 09:46 PM
disabled EGR, now throwing code dchriste Camry & Solara Lounge 9 04-23-2006 03:14 AM
Need some info... comets Archived Corolla threads 11 03-03-2003 10:26 PM
