Rough engine idle Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2006, 08:05 AM   #1 (permalink)
Roleyz
View Roleyz's Photo Gallery
Hi, i have a 91 turbo that I have been building since Jan 06, just got the rebuilt engine back from precision engines, replaced all hoses, etc. New plugs, wires, (did not replace rotor cap). I installed all of it, started up fine but was running rough. Reset the timing to 10 degrees BTDC, Note(I dont have the exhaust on it yet so it was running with a straight pipe for about 3 minutes) Anyways to my question: Could the lack of backpressure from not having the exhaust on it cause that rough idle? if not do you all have any suggestions, also when I give it gas it tends to hesitate and sometimes backfire?
Thanks
Roley
Roleyz is offline   Reply With Quote
Old 10-22-2006, 06:24 PM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
in a turbo... absolutely.
sucking air out faster then its coming in. definately cause misfires... lack of power.i wouldn't run it longer than you have to... prevent damage
tHa kNiGHt FaLL is offline   Reply With Quote
Old 10-23-2006, 07:55 AM   #3 (permalink)
Roleyz
ok cool, I did get the stock exhaust back on and i still have the same problems, I am thinking now that I need to have it hooked up to a diag machine to see if I have any faulty sensors, etc? I am thinking now it has to be electronics since the block, turbo, etc is all new? maybe even injectors?
Old 10-26-2006, 07:18 PM   #4 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
hmm
I think I have seen this post b4... As far as ideas, I believe that taking it to the dealership, or a very trusted and much cheaper mechanic should be on speed dial... stinks that it's happened man I know the feeling, I just hope for your sake it is a cheap ordeal!!
good luck :Brian
Zz_005_zZ is offline   Reply With Quote
Old 10-27-2006, 07:13 AM   #5 (permalink)
Roleyz
Thanks Brian, I did call the dealership and the guy i spoke to asked me when is the last time i put fresh gas in it? DUH! I didnt even think of that, I bought the car in Jan 06 drove it home and tore it apart, I have no idea what is even in the tank. I am going to drain the take and try fresh gas first, then on to the dealership (on a trailer) Jim
Old 10-27-2006, 08:10 AM   #6 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
I ran Hyde for a good 2 or 3 years with a straight out exhaust.
Not having exhaust back pressure will not cause a turbo MR2 to idle rough.
The turbobien itself will cause back pressure.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Tercel 43fte engine swap, won't run right farmermoose Tercel, Paseo, Starlet, and Sera Forum 1 09-19-2006 09:28 PM
Engine misfire - clutch vibration - some what rough idle? blueapple Camry & Solara Lounge 0 04-08-2006 03:48 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
