can i pass smog? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2006, 11:42 AM   #1 (permalink)
View jesse0880's Photo Gallery
can i pass smog?
is there any way i can pass smog without the primary cat? i have all the smog equipment on other than that and the visual is not an issue. if not, what can i do?
jesse0880 is offline   Reply With Quote
Old 10-29-2006, 05:32 PM   #2 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
what year mr2 do you have and is it turbo or n/a? where at in cali do you live?
mr2_dori is offline   Reply With Quote
Old 11-11-2006, 11:50 PM   #3 (permalink)
1991 mr2 turbo. i got a greddy turbo upgrade kit on it right now ( tdo6 kit). all the smog equipment is on except the main cat. i do live in cali. but keep in mind that the visual is not an issue. what can i do?
Old 11-12-2006, 10:17 PM   #4 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
you do not have the catallic converter on the car you will not pass smog or any emission test for that matter.
thats the entire purpose of a cat is to clean the exhaust gases.
wha can you do...?
well if visual is not a problem that means you must know someone that does smog. pay him to pass the car for you or get a cat and put it on
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-16-2006, 12:37 AM   #5 (permalink)
can i get a new cat and have it welded somewhere in the stock exhaust system after the downpipe? i know the exhaust system is a tight squeez for that type of mod but is it possable? i really dont wanna but back on the stock turbo cause thats alota labor and plus the turbo doesnt look so good.
Old 11-16-2006, 03:30 AM   #6 (permalink)
Audi Technician
i still don't get it...
if you removed the cat... you had to replace w/ something... like a test pipe... just remove the pipe and install a new cat... no welding necessary cause the cat bolts to the exhaust manifold
Old 11-17-2006, 01:03 AM   #7 (permalink)
http://www.mr2.com
View Ncturnal's Photo Gallery
Do you have an aftermarket exhaust? On the stock exhaust there is typically room for a high-flow cat. Most aftermarket exhaust have a short b-pipe that you could replace with a section that had a cat integrated. Otherwise, just put the stock cat back on for the test, although I recommend permanently running one of the high flow options if you can.
Ncturnal is offline   Reply With Quote
Old 11-19-2006, 11:09 PM   #8 (permalink)
the reason that the stock cat is not on the car is that it wont bolt to the tdo6 turbo thats in the car already. sorry if i didnt mention that earlier. i just needed to know if i could fit a new cat in the system after the down pipe.
Old 11-23-2006, 05:57 PM   #9 (permalink)
Audi Technician
a place like mieneke can take a universal and cut and weld to fit... thats wha they did w/ mine
Old 11-29-2006, 02:29 PM   #10 (permalink)
cool. i'll try that. thanks
Old 11-30-2006, 02:26 AM   #11 (permalink)
Audi Technician
yea don't believe that... cause last minute i mieneke said it couldn't be done w/ a universal so i had to get the part from the dealer and i gotta do it myself this weekend
Old 12-19-2006, 09:44 AM   #12 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
On a non turbo I'd say maybe... but no chance on the turbo without one.
Any custom exhaust shop can cut out a small section of pipe and put one in.
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
pass smog? jesse0880 MR2 Forum 6 02-24-2006 10:19 AM
Can't pass smog...suggestions anyone??? rdayton_67 Camry & Solara Lounge 31 12-02-2005 01:37 PM
smog check Pass or not? KamryStylez Camry & Solara Lounge 14 11-24-2004 05:30 PM
Smog Check Pass or Fail? a94autoCamry Camry & Solara Lounge 10 02-10-2004 06:43 PM
MR2 doesn't pass smog edgarchan MR2 Forum 1 12-03-2003 11:17 PM
