Speedway MR2 RPM problems HELP!
hey im racing a 1990 ish MR2 with the 2.0 dohc turbo motor.
we run in 2nd gear and 1/2way down the straights the car seems to be hitting a limiter type problem (i think).
the problem only happens at high RPM but does not sound like a RPM limiter to me. It sounds like a rapid noise and will continue untill you lift your foot of the pedal.
the car is mildly tuned: its runs -
Link ECU
Large fuel system
exhaust system
10-12psi boost - manual controller
standard turbo.
all the rest is factory.
to me its sounds like its dropping a cylinder through soft valve springs but in am still unsure
was woundering if anyone else has had of heard of this problem
cheers
