non turbo to Turbo swap¿?¿?¿? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2006, 12:32 AM   #1 (permalink)
View rpm22's Photo Gallery
Hi im new here. i was wondering how hard it would be to swap a turbo motor into a non turbo mr2, if u had the ecu and all the wiring. Ive heard u have to pull the motors from the bottom on the mr2s bc they are mid engine is this true and if so how hard is that if u can get it on a lift. any info would help thanks
rpm22 is offline   Reply With Quote
Old 10-30-2006, 03:32 PM   #2 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
well mr2's are hard to chance out. you do have to get a lift and the engine comes out the bottom. you will need ecu, wireharness, tranny, engine,axles. if you buy a rear clip then you should be able to do it just fine. but you have to no what your doing if your going to do this swap yourself. i swaped a 97 3rd gen 3sgte in my 92 non turbo.
mr2_dori is offline   Reply With Quote
Old 10-30-2006, 06:58 PM   #3 (permalink)
how complicated was ur wiring harness did u put it together urself or did u get a half cut with everything.
Old 10-30-2006, 08:30 PM   #4 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
Whoa
First of all, the engine definately has to come out from the bottom, I pulled out the 2.2 liter from my 91 N/A years ago, replaced the clutch, and did all of this from the top... it was a pain in the ars, and I almost broke the back window with the tranny... is was NOT fun... especially using a blazer as a engine hoist, lmao.... we youngins always think of doing the stupidest things...... after was all said and done, we ended up giving the car back to toyota with an engine and tranny away from the car, and a bucket of bolts to go along with it. We said put it back in... It took us two dayas to get the motor, tranny out and replace the clutch.
I feel very sorry for the mechanic, but this was only replacing a clutch... so I highly recommend taking out from the bottom. The car I currently just bought has the motor swap, and it is fantastic. I would highly recommend it to any non-turbo mr2 owners.
It is expensive to do the swap even if u do it yourself, and a long journey.... but you would definately be better off buying the rear clip, like the last person said, and replacng, the ecu, motor , tranny, and engine along with the axles and so on and so forth... u will SAVE alot of mula doing it this way, plus u get an extra rear spoiler, gas cover, ect.
Wish you luck m8. : Brian
Zz_005_zZ is offline   Reply With Quote
Old 10-31-2006, 08:32 AM   #5 (permalink)
MAX BOOST!!!!!!!
FS: 22RE Turbo kit Full Boogie Car Parts for Sale 18 09-16-2009 03:42 PM
RARE Turbo TRD TOYOTA Solara 2.2 5SFE 5spd 2000 one of kind $8500 trdcamrygracia Vehicles 15 11-27-2006 12:01 AM
My Official Turbo Post!!! 97camryman Camry & Solara Lounge 25 07-20-2006 04:48 PM
oil and turbo eclypz MR2 Forum 9 08-03-2004 07:15 AM
are the non turbo and turbo the same? blitzed95eclips MR2 Forum 3 05-01-2003 03:17 PM
