Racing question?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2006, 10:00 PM   #1 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
Racing question??
Once apon a time... I was passenger in a 1998 toyota supra tt... Only a few mods were to be appreciated, such as exhaust and an intake. After a carshow, we were about to enter a race from a 30 mph roll with a firehawk. Now I know the firehawk is a rare and somewhat fast car.. I noticed that my friend was lightly pressing the brake giving gas, and letting the clutch out slowly... thus spooling up the turbo. When he dumped it, we shot through the seats and into the trunk ( not really but u get the idea). The firehawk owner couldn't believe it. This bieng said, does the same go for the mr-2, and yes I know it's horrible on almost every moving part on the car other than the motor. At 0 mph, and at slow speeds??
I figured this would be a rare, and conversational topic
Zz_005_zZ is offline   Reply With Quote
Old 11-02-2006, 03:25 PM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The turbo builds boost based on load onthe engine.
Asking the engine to hold a given mph while the brakes are being applied will put a serious load on the engine .... which will build boost. Once you let go of the brake, and go WOT, the car will rocket off at high boost.
I don't think it is any worse on your car than racing the engine generaly is.
However, it is terrible for your brakes
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 11-04-2006, 12:47 AM   #3 (permalink)
Young At Heart
ok
I really need to know if this is a good launching technique at the track... u would be the right guy to ask I am guessing
Old 11-04-2006, 06:26 AM   #4 (permalink)
I love Cin
It would be harder to do at the track as you would need a third foot to hold the brake in place, but it is possible.
It is a lot easier to set up a 2-step rev limiter which builds boost for you at the line without playing games with the brake. I'm making upwards of 30 psi of boost before I ever let the clutch out
Old 11-04-2006, 04:51 PM   #5 (permalink)
Young At Heart
Sweet
Now that makes sence... How do u get the limiter, and what is the basics on pricing?? I am really curious on this 1
Old 11-04-2006, 08:59 PM   #6 (permalink)
Cruisin' Colorado
View Turn 180's Photo Gallery
Possible to have a third leg? haha just giving you a hard time.
Yeah i'm curious about that... How would the secondary reve limiter work? is ther a kill switch for it that then allows the higher rev limiter to work?
I guess this is an idea I have never heard of before... MORE INFO PLEASE!
1991 MR2 Turbo SW20 3SGTE
1996 Camry DX 5SFE
1983 Mazda RX7 12B Rotary
Turn 180 is offline   Reply With Quote
Old 11-05-2006, 07:31 AM   #7 (permalink)
I love Cin
We all have at least one rev limiter from the factory that limits the car at redline.
What a 2-step does is offers a second rev limit that is set lower (mine is at 6300 rpms) so you can go full throttle while sitting still with teh cluthc in.
Once you go WOT, the revs nail the rev limiter and iginition spark and/or fuel gets pulled which starts a load backfiring ... the load on the engine at WOT is enoguh to start building boost.
Once you let the clutch out, the car returns to the regular rev limit.
This is controlled by a switch on the clutch ... it's easy enough to just use the cruise control switch that is already on the clutch.
As far as I know, there are 2 routes to getting a 2-step rev limiter.
I have the Hydra Nemesis EMS (engine management system) which has a programmable 2-step built into it.
The other option is to buy an MSD ignition box and buy an MSD ignition 2-step revlimiter that wires into it.
Here's a close up video of the flames I get from the 2-step:
http://www.jekylhyderacing.com/image..._2stepping.mpg
Here's a video of the 2-step doing it's job to get a 1.49 in the 60 foot (since it is at night, you can see the flashes from the 2-step under the car:
http://www.jekylhyderacing.com/image...nd_dragway.mpg
Old 11-05-2006, 06:04 PM   #8 (permalink)
Cruisin' Colorado
Great I just have one question... WOT is that with out throttle? what exactly does that mean?
1996 Camry DX 5SFE
Old 11-05-2006, 06:35 PM   #9 (permalink)
I love Cin
WOT = Wide Open Throttle
Full throttle
Old 11-05-2006, 08:54 PM   #10 (permalink)
Cruisin' Colorado
Ok now everything makes more sense Awesome
1996 Camry DX 5SFE
Old 11-05-2006, 09:27 PM   #11 (permalink)
Young At Heart
Kewl
Your mr-2 sounds badass!!! I love it, lmao..... man I want a hyde for myself now!!!!!!
Nice man
Old 11-06-2006, 02:03 AM   #12 (permalink)
Cruisin' Colorado
Is this the device you are talking about?...
http://www.msdignition.com/rpm_5.htm
Or would this be more like what you are talking about
http://www.msdignition.com/rpm_6.htm
1996 Camry DX 5SFE
Old 11-06-2006, 04:59 AM   #13 (permalink)
I love Cin
This is the one I used to have:
Old 11-06-2006, 11:11 AM   #14 (permalink)
Cruisin' Colorado
Ok so you have the two or three step limiters... will that run off you stock ignition or do you need to buy an aftermarket MSD igintion so it all works together?
1996 Camry DX 5SFE
Old 11-06-2006, 11:17 AM   #15 (permalink)
I love Cin
As I indicated above, I am using the 2-step.
I am no longer using the MSD unit though.
In order to use this, you will need the MSD ignition, you will need the individual modules (pills) that set teh RPM points and you will need the MSD Soft Touch Rev control.
... you will also need tires that can hold the power of boost coming off of a launch
If you are not using drag radials and racing at the drag strip, it would be a pointless purchase as you will most likely just roast your tires and not hook up very well.
Question about 99 Camry Rear Suspension Arms smahan Camry & Solara Lounge 11 03-16-2012 09:21 AM
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Racing Seats blkdmnrcing General Discussion 13 03-09-2006 09:17 AM
Performance & Racing Camshafts...question RichieRichJP Camry & Solara Lounge 15 11-03-2005 09:25 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
