Tough
Well first of all, u are looking at running all the way to the back, and on an mr-2 u are running on a cv-axle, which would keep you front wheel drive, the 3sgte is a turbo motor, and is a 2.0 with 200 hp at the flywheel... The N/A version of the mr-2 is a 2.2 liter 4 cylinder, so thats over your size dimensions. And I believe that the celica all trac is front wheel drive, so u might be better off going with maybe a solara engine, which are almost all 4 cylinders, however I duno the size of the motor... Wish I could be more help : Brian
