3s-gte engine problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2006, 09:15 PM   #1 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
View Zero turbo's Photo Gallery
Exclamation 3s-gte engine problems
ok so my engine is acting strange. each time i turn the car on i have to give it a lot of gas so the RPMS wont reach 0 and even when the engine is hot it stills does the same thing.
And the turbo timer always resets. and if i am at a stop light and turn the A/C on the car goes from 1,600 rpms to 800 rpms and even sometimes turns off. so anyone has a idea??
Thx in advance...
1-Chuck Norris is the reason why Waldo is hiding
2-When Chuck Norris does a pushup, he isn’t lifting himself up, he’s pushing the Earth down
3-The Guinness World Book of records shows the people that have come the closest to the skills of Chuck Norris.
Zero turbo is offline   Reply With Quote
Old 11-04-2006, 11:07 PM   #2 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
Weird
I am not too sure, however my car idles at 1,000 - 1100 rpm's, without the a/c on...
it might have to do something with your throttle positioning sensor (tps) or u might need new spark plugs, or u might have bad gas, u might need a fuel pressure regulator, or a new fuel filter
Zz_005_zZ is offline   Reply With Quote
Old 11-05-2006, 07:19 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
It sounds to me like you have a leak in your intake.
Do you have an AFM car?
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 11-05-2006, 12:23 PM   #4 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
what is a AFM car?? the fuel filter is almost new i replaced it like 3 months ago. I did put regular gas on it (83 octane) well it was my father that did it (dumbass ) but i put a octane bosster in maybe that could be the problem,i got new spark plugs today and still does it so dont know i will take it to the mechanic...
Old 11-05-2006, 04:26 PM   #5 (permalink)
I love Cin
AFM = air flow meter.
If you have a turbo MR2 from the US, it will have the AFM.
Some of the later years in Japan did not use an AFM.
It sounds to me like you have a leak in the intake tract somewhere.
Old 11-06-2006, 08:28 PM   #6 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
83 octane?
i thought you weren't supposed to put lower than 91 in a turbo car.
lower gas will cause pre-ignition in a turbo vehicle.
so a octane booster won't work. cause if you read one boost is equivalent to like .8 percent. so you would need like 10 of them to make a difference.
i would suggest... you drain that stale ass gas out and fill with the highest octane you can find and let it run for about an hour to get all that shit out
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-06-2006, 08:51 PM   #7 (permalink)
I love Cin
83 octane would not cause preignition while he is sitting still trying to idle.
Regardless, that wouldn't cause the car to want to stall out.
Old 11-06-2006, 09:08 PM   #8 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
hey i solved the problem it was a Vac. hose that the previous owner had cut and shut close with silicone , the silicone fell off and that coused the problem so i shut it close with a metal cap. But Jeff you where right the hose goes to the intake...
Old 11-06-2006, 09:10 PM   #9 (permalink)
I love Cin
Glad you found it ... now get some real gas in there
Old 11-06-2006, 09:44 PM   #10 (permalink)
Young At Heart
:0)
Man u had it easy!!! I always check the easy stuff first...however if it makes u feel better... I posted this problem I had... which nobody ersponded to might I add, and thought it was my engine mounts making this clunk noise every time I would huit a small bump, or gave it throttle and let off fast...also when I started from 0 mph to start out in 1st gear it would make this creeeeek noise... turns out it was just the aftermarket air filter that was put in.. the bolt that holds it to the firewall, came loose, and it was clunking around.. go figure, ever since I always check the easy stuff first
Old 11-06-2006, 09:56 PM   #11 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
LOL well i have had a grinding noise beneath my dash console(below the radio to be exact) if as 2 pieces of metal vibrate together and no mechanic has found where does it come from and the sounds become really loud under hard Accel. who knows what would it be until it finally brakes !!
Old 11-07-2006, 02:47 AM   #12 (permalink)
Audi Technician
cheap gas could cause pre-ignition.
turbo equals more air, compressed air.
higher the octane the slower the burn. you need a slower burning fuel to to make sure the entire mixture of the compressed cylinder burns. a cheap gas would cause the mixture to burn faster. and the higher combustion temperatures of a forced inducted car could cause the lower volitle fuel to burn on compression w/o spark causing pre-ignition
Old 11-07-2006, 05:22 AM   #13 (permalink)
I love Cin
yes tHa kNiGHt FaLL that is all true, but he was not talking about having a probem while boosting. He was a having a problem while sitting still, trying to get the car to idle. The turbo is not making positive manifold pressure at that point so there is no need for a higher octane.
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
Engine idling problems jcb62988 1st & 2nd Generation (1983–1986 & 1987-1991) 11 09-26-2006 09:36 PM
2000 camry engine problems help? LONG jotka 3rd & 4th Generation (1992–1996 & 1997–2001) 10 03-24-2006 10:16 PM
engine problems while on highway MR2Enthuze MR2 Forum 1 12-24-2005 02:04 PM
99 Camry Engine problems Phatslugga Camry & Solara Lounge 5 10-03-2005 10:49 PM
