fixing the problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2006, 08:19 AM   #1 (permalink)
jdm 2nd gen ftw!
View nepopolus's Photo Gallery
fixing the problems
ok after a while this jdm motor has run great but things are starting to break on it (i figured this seeing as how i do autocross and drag) but anyway does anyone know the prices for these replacement parts?
transmission may get rebuilt fully all new syncros (2nd gear is grinding at high rpm's will NOT go in no matter what i do) all the other gears are fine i just want to get all them replaced because i know as soon as i fix it anotherone will go out
is the trans rebuilt worth it ? how much is a new one with and without lsd
alternator sqeaks when battery is at a low charge is about 180$ at autozone for a new one i think i can do this myself but is there any annoying things i need to look out for when replacing this ?
after these it is back to upgrading it and getting it ready to race for the spring summer and fall just like this year
nepopolus is offline   Reply With Quote
Old 11-08-2006, 08:58 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
I would contact CraiggieB on www.mr2oc.com.
He sells parts for Thompson Toyota and gives us great prices.
Tell him I sent you.
The 93LSD trannies are actually cheaper (and a LOT better) than the 91s.
If you are buying a tranny, I would suggest you buy the 93.
If you can afford it, go the LSD, but you will also need new inner stubs for your axles.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 11-08-2006, 12:18 PM   #3 (permalink)
Wasnt Me!!
View deuce93t's Photo Gallery
as for the tranny i dont know exactly what a new one will cost you but i can tell you this i just recently last year had my 2nd gear done in my 21 and the gear alone was $720 becuase toyota no longer makes the 91 2nd gear! along with all of the other work that goes with rebuilding the gears and putting it back in was around $1600 and the guy said that he took some off the price becuase he felt bad the gear was so much! so i would say cost to effect ratio go with the new tranny even if you cant race this coming year. The power is no good if you cant get it to the ground! i agree with hyde check with mr2oc they will best be able to give you a dollar figure on a tranny! good luck and keep her out of the wall!
deuce93t is offline   Reply With Quote
Old 11-08-2006, 12:55 PM   #4 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
This might help
http://cgi.ebay.com/JDM-TOYOTA-MR2-S...em230048006697
This is limited slip differential from e-bay. get u an idea of the price.
http://cgi.ebay.com/JDM-TOYOTA-MR2-2...em220045822729
This is a used engine and transmission... so for the price of the rebuilt tranny u could have an extra parts engine!!
Zz_005_zZ is offline   Reply With Quote
Old 11-09-2006, 04:59 AM   #5 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
you got raped dawg... 720 for one gear... you can get an entire rebuild kit for 300.00 and pull the gear outta a junk yard trans
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-09-2006, 05:11 AM   #6 (permalink)
Young At Heart
true
However if u can just get the whole engine and transmission for 12-1300 $$ u would get an extra engine to build up, or just use for spare parts, plus doing a rebuild is an absolute nightmare... Then u are hoping u get a good 5th gear after all that work.... sorry but that sucks, plus junkyards are really expensive as they treat their cars like gold peices of garbage.
Known problems slcpunk General Lexus Discussion 3 12-16-2005 11:51 AM
Electrical Problems - Searched and found little help. Delay_FTB General Discussion 5 12-05-2005 03:43 PM
electrical problems arising... battlekat49 Camry & Solara Lounge 2 08-14-2005 01:40 AM
Power Door Lock/Window Problems digger1978 Camry & Solara Lounge 4 06-28-2005 02:44 PM
