Ecu upgrade. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2006, 05:45 PM   #1 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
View Zero turbo's Photo Gallery
Ecu upgrade.
Hey there is a guy selling a 3rd gen 3s-gte JDM Ecu. Is this Ecu a direct upgrade from my 2nd gen usdm ecu?? if so what would be the gains?? and another question what is a better upgrade a intercooler or a downpipe?? thx in advance .
1-Chuck Norris is the reason why Waldo is hiding
2-When Chuck Norris does a pushup, he isn’t lifting himself up, he’s pushing the Earth down
3-The Guinness World Book of records shows the people that have come the closest to the skills of Chuck Norris.
Zero turbo is offline   Reply With Quote
Old 11-09-2006, 06:05 PM   #2 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
As for the second question, I would say the intercooler, but replacing the b pipe is the best bet on the mr2 not the downpipe
Zz_005_zZ is offline   Reply With Quote
Old 11-09-2006, 06:50 PM   #3 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
you'd be dumping your emissions data. might have a different air/fuel setup... but you can get that w/ an aftermarket fuel press regulator.
upgrading an intercooler has about the save effects as upgrading your intake system on any normal car.
too small is bad
too big is bad
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-09-2006, 07:43 PM   #4 (permalink)
http://www.mr2.com
View Ncturnal's Photo Gallery
The 3rd gen ecu won't work on your gen2 car. Don't waste your time or money with it. The Gen3 ditched the AFM and uses the map sensor instead. The wiring and pinouts are different. The fuel maps are different, and the gen 3 used bigger injectors, among several other differences.
#2- Better depends on your goals. The IC is a safety measure against detonation, so I'd personally recommend it first.
Ncturnal is offline   Reply With Quote
The Free Mod Series - Part IV Cheaply Monitoring the ECU & A/F Toysrme Camry & Solara Lounge 10 08-16-2009 09:54 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
Camry ECU UPGRADE import4life Camry & Solara Lounge 14 04-12-2005 04:00 PM
Interior Lighting luisitol Camry & Solara Lounge 23 10-17-2004 03:18 PM
ecu upgrade and speed sensor Horseflydf Celica Forum 2 06-25-2004 04:29 PM
