Moroso oil pan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2006, 07:42 AM   #1 (permalink)
View K'tara's Photo Gallery
Moroso oil pan
I was thinking about getting the Moroso oil pan for my 3sgte and someone said I would need to get a pick up for it.
Exactly, what do they mean, if anyone can tell me?
Thank you.
K'tara is offline   Reply With Quote
Old 11-13-2006, 07:46 AM   #2 (permalink)
Fist of the North Star
View Komodo's Photo Gallery
They are reffering to the oil pick-up. But I don't think you need a different one, stock should work. If I'm wrong someone will correct me.
Komodo is offline   Reply With Quote
Old 11-13-2006, 07:49 AM   #3 (permalink)
yes, please. I am wondering as well. If I do need a pick up, would it be because the pan is possibly deeper than the stock?
Old 11-13-2006, 11:32 AM   #4 (permalink)
I don't think the pan is any deeper than stock. It has kick-outs to increace volume.
http://www.moroso.com/catalog/catego...?catcode=20935
It even says at the bottom of the page to use stock pick-up.
Old 11-13-2006, 02:16 PM   #5 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
I would not recommend this piece.
From what I recall, there are serious issues with exhaust interference ... apaprently it was designed on a car that had not had the exhaust in place
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 11-13-2006, 02:16 PM   #6 (permalink)
http://www.mr2.com
View Ncturnal's Photo Gallery
I recall reading some issue with the Moroso oil pan quite a while ago (couple of years ago) on mr2oc. You might try doing some research there.
Ncturnal is offline   Reply With Quote
Old 11-14-2006, 06:04 AM   #7 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
i don't see how an oil pan helps woth performance anyways... until you have a problem w/ oil supply in your motor... i wouldn't even bother. if you think it looks cool well then just paint the stock one pink or something. that will proly draw the same amount of attention.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-14-2006, 07:03 AM   #8 (permalink)
Well, I'm getting a custom exhaust built, so the whole thing about that wont be a problem.
The reasons why I am thinking about that pan is because I'm getting ATS's stroker and I'd like to have a new pan with it as well, also cause I dont feel like drilling a hole for the return line. So yeah, I'm lazy at one point.
Old 11-14-2006, 07:26 AM   #9 (permalink)
I love Cin
If you are getting a custom exhaust built ... you are going to need a custom downpipe for your turbo. From what I recall, the issue with the oil pan is that it is right in front of where 95% of downpies exit.
Good luck with your project.
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Does the Oil Pan have a gasket? NickR Tercel, Paseo, Starlet, and Sera Forum 8 06-28-2006 08:55 AM
Oil pan question? White89SR5 Archived Corolla threads 4 10-07-2005 06:14 PM
Anyone changed out an oil pan?? 89_3SFE Celica Forum 4 11-29-2004 03:59 PM
Leaky Oil Pan Gasket??? 90celica Celica Forum 9 03-12-2004 01:54 PM
