Oil pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2006, 07:19 PM   #1 (permalink)
View drkblu's Photo Gallery
Oil pump?
i'm hearing some noise in the engine bay when my '92 runs for the first few minutes of the day. once the car warms up, the noise subsides. this noise is something i would describe as metal rubbing against metal at a fast rate. the oil level is at full, however i have no way of checking the oil pressure myself. any one know what could be causing this noise?
drkblu is offline   Reply With Quote
Old 11-14-2006, 05:35 AM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
goes away when warm...?
normally most internal sounds gets worse w/ heat expansion.
i think you need to narrow down sound location. between crankcase or head. i imagine its in the crackcase but the source could be multiple of issues
now does it sound like pinging or banging sound or more like scraping?
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-14-2006, 03:25 PM   #3 (permalink)
sounds more like scraping to me....possibly a shrill wizzing sound similar to that of a drill
Old 11-14-2006, 06:23 PM   #4 (permalink)
Audi Technician
from the block?
you got a clearance issue most likely.
has anything happened to the engine in the past say 6 months.
something like this isn't done on its own... usually forced from something noticable.
your going to have to do an oil pressure test... bottom line first thing to do.
Old 11-14-2006, 10:52 PM   #5 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
hmm
Does your car smoke at all on startup... sounds like something in the valvetrain. But a Drill sound.. u kinda have me stumped there... does it sound like the noise is coming from inside the motor, or have u the chance to listen in the engine bay to about where the noise is coming from... Valve seals will make a light tapping noise when started, smoke a bit, then slowly but surely go away... I am sure you already know this... but I am just throwing ideas out there
Zz_005_zZ is offline   Reply With Quote
Old 11-15-2006, 02:18 AM   #6 (permalink)
View toyomoho's Photo Gallery
Check the area of the water pump, alternator bearings, PS pump (if you have one).
2.7L oil capacity incorrect gonesurfing 2nd Generation (2005+) 34 02-11-2011 12:09 PM
Low oil pressure after timing belt & oil pump seal change Hot66ss Camry & Solara Lounge 9 05-07-2006 08:44 AM
performance oil pump? profitwho007 Camry & Solara Lounge 5 01-24-2005 12:53 PM
1990 ES250 Oil Pump seal ArmyofOne 1st & 2nd Generation (1983–1986 & 1987-1991) 1 01-11-2005 05:46 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
