91 MR2 Needs "EGR" valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2006, 08:20 AM   #1 (permalink)
View PLight5459's Photo Gallery
Was told by the mechanic that my car needs a "EGR" valve. The valve is clogged and that's causing the car to cut off occasionally when the brake is applied. He didn't have the part, nor could he provide an estimate. Has anyone had this problem?
PLight5459 is offline   Reply With Quote
Old 11-15-2006, 11:20 AM   #2 (permalink)
View 91ghosttuner's Photo Gallery
egr
I haven't had this problem with my MR2 but it did happen with my truck. More times than not if the problem is simply that the EGR is clogged, and not the pressure sensor then you can just take out the EGR and clean it with carbon cleaner, or with a little rubbing alcohol. I clean them with q-tips. When you use them they will come out black for awhile. Keep cleaning until its grey. This works most of the time, like 9-10, and is free!
Hope this works for you!
91ghosttuner is offline   Reply With Quote
Old 11-15-2006, 03:03 PM   #3 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
you sure he tested it right...?
its a negative transducer type EGR... so that means it opens w/ the absence of back pressure in your exhaust.
most mechanics just apply 10 hg of vacuum to see if the engine stumbles or not.
if it doesn't they condem it w/o understanding there is 7 different types of EGRs all test differently. its has a load sensing solenoid that prevents it from even opening by playing w/ the throttle... the vehicle has to be moving.
and EGR is a emission control device. all it does it recycle exhaust air to lower combustion temperatures to prevent the formation of NOx.... NOx is the 5 gases which i thought was only tested for in California... every other state uses 4 gas.
so smart things to do... is buy a vacuum pump for 30.00 and a factory manual you can get on ebay for 15.00... now factory manual.... not chiltons...
and read and test it yourself.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-15-2006, 06:44 PM   #4 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
KnightFall
I am guessing that u are a mechanic?? Cause u know alot more than me when it comes to sensors, and such
Zz_005_zZ is offline   Reply With Quote
Old 11-16-2006, 03:39 AM   #5 (permalink)
Audi Technician
yea
technician... cause i understand what it is i'm fixing ans why... mechanics just replace shit
can i fit a '91 MR2 engine in my '92 Tercel boxface Tercel, Paseo, Starlet, and Sera Forum 22 03-04-2008 06:10 PM
91 Mr2 with 93 Turbo Engine, IN SAN DIEGO/CA NiX Vehicles 15 07-15-2005 11:34 PM
Thinking On Buying A 91 MR2, Should I Or Shouldn't I ? Melly MR2 Forum 12 06-08-2005 09:20 PM
91 MR2 purchasing help!!! Rogi MR2 Forum 2 05-26-2005 11:25 AM
