Originally Posted by MRQturbo
proper sized rims with wb offsets will not require the need for spacers....
While that is true, leaving the suspension allone will move your scrub radius in with wider offset wheels.
I ran into this with my last widebody. When you just add offset to the wheel you screw up, among other things the steering geometry. This will lead to poor turn in, darting under braking and other problems. You dont really need that much front tire on the MR2. Moving the hub out is a good alternative if you have the know how to do it.
