Erratic Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2006, 08:23 AM   #1 (permalink)
View jamminn07's Photo Gallery
Erratic Idle
I recently purchased an 86 MR2. The car mechannically is sound however, until it warms up, the engine revs from approx 500-1500 rpm. Any ideas?
jamminn07 is offline   Reply With Quote
Old 11-25-2006, 10:41 AM   #2 (permalink)
TokyoRacer's Avatar
View TokyoRacer's Photo Gallery
Could be EGR related, if that car has an EGR
Kyle's 1990 Corolla SR5 - 2001 Protege ES
TokyoRacer is offline   Reply With Quote
Old 11-25-2006, 11:51 AM   #3 (permalink)
View MKI_S/C's Photo Gallery
Gen1
theres air in your coolant system that is what gives the unconstant idle until the thermostat opens and the air is moved through the system
MKI_S/C is offline   Reply With Quote
Old 11-25-2006, 07:02 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
When you starting the engine cold, it is normal for the idle to be 1200-1500rpms until it reaches a sufficient operating level. Do the RPM's drop after it's warmed up?
The Jedi Speeder at CarDomain
Old 11-25-2006, 09:32 PM   #5 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
Hmm
I would try MK1/SC 's idea first and foremost, bleed the radiator of all air, which is not an easy task, but at least it won't cost much!!
Zz_005_zZ is offline   Reply With Quote
Old 11-26-2006, 03:25 PM   #6 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
it only idle erratic at idle when the car is cold...?
when its warm it doesn't do it at all...?
i'm thinking something along the lines of ISC is stuck or not working at all...
its early in the morning... but i'm having trouble seeing how air in coolant effects idle...
air in coolant would effect the expansion process and cause a heating/cooling issue.
ISC allows air to bypass the throttle plate in cold start situation...
also i dunno the 4age setup but check to see if you have a cold start injector... it will be in the intake manifold. check the resistance across it... i don't own an AW11 so i don't have a manual to check the specs but i'm sure you can find it online
some more info please and maybe we can narrow it down
tHa kNiGHt FaLL is offline   Reply With Quote
1986 22re with erratic idle flemingd Pre-88 Toyota Pickup/Hilux 2 07-14-2006 05:45 PM
Rough idle, gas smell, erratic drive blackaneseazn Celica Forum 13 01-23-2005 10:07 PM
No Idle after motor rebuild wrenchdad MR2 Forum 0 01-09-2005 08:19 AM
91 Celica GT idle erratic SoulSoldier Celica Forum 1 06-24-2004 10:53 PM
Erratic Idle Minuets Archived Corolla threads 16 02-15-2004 11:51 PM
