Clutch problem
I am currently at school and away from my tools, but overnight my clutch took a shi* on me. I come out in the morning and start the car, I attempt to go into all gears and I hear a grinding noise. I had a brandnew master cylinder installed with a new clutch. The shifter moves into all gears when the car is off, but none when car is on.
I looked at master cylinder and all the dot 3 was gone. I checked comon places for possible leaks, and cant seem to find one.
So now i need to know if i risk refilling and attempt to drive home? Will that be safe since im only a hour and a half away?
And upon refilling I will have to bleed it to correct?
Finally i need to where the slave cylinder and is and what does it do?
Thanks very much
