Weird Boost Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2006, 11:23 AM   #1 (permalink)
View 430hpToy's Photo Gallery
Weird Boost Problem
Out of no where the other day i started having this weird boost problem with my mkii.
If i start to get into boost under half throttle the car starts to jerk, shake, & bog...
If i get into boost at full throttle there isn't really any problem except the strong smell of raw fuel which just started as well...
The car runs & idles fine without boost.
I'll probably start digging into it over the weekend if i have time, but figured i'd see if anyone else ever came across this problem and had any suggestions.
Thanks!
-Mike
8. No commercial/business/website promotion in Signatures. The only URLs allowed in signatures are to your own car's personal website or another Autoforums.com website. No exceptions!
430hpToy is offline   Reply With Quote
Old 11-29-2006, 12:22 PM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Ignition: How old are your cap, rotor, wires and plugs?
I would change the first 3 once per year and the plugs every 3000 miles.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 11-29-2006, 12:40 PM   #3 (permalink)
hmmmm..... good point! i usually try to change the cap and rotor about every other oil change but haven't for some time now! i'm sure they're both toast by now!!!! lol
Thanks! Hopefully that's the problem!
Old 11-29-2006, 01:00 PM   #4 (permalink)
I love Cin
... I'd be worried about the wires first.
Old 11-29-2006, 01:22 PM   #5 (permalink)
really!?!?!? i don't have the stock wires on it! i have the magnecor 8.5mm... i know the stock wires are usually pretty crappy but haven't really had any problems as of yet with the 8.5's. allthough i guess it's still possible... i've had them on the car for a little over a year now.
Old 11-29-2006, 01:29 PM   #6 (permalink)
I love Cin
How much mileage on them and how much boost do you run?
The stock wires are wonderful, not crappy.
Our cars just eat wires regardless
All I run is stock wires.
Old 11-29-2006, 02:16 PM   #7 (permalink)
there is probably about 8k-10k on the wires.
i run at about 14psi.
i remember when i first did the swap and had the oem wires on it they didn't last very long. i was having ign. problems a few months later and it turned out that the main problem was the wires. replaced them with oem's again and later replaced the oem's with the magnecor's and haven't had any ign problems until now. i'll def. check the resistance of the wires to see how bad they really are, but i'll bet the main problem is the cap and rotor... if the problem is the wires then they def. lasted a hell of a lot longer than the oem's!
Old 11-30-2006, 02:38 AM   #8 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
yea i kinda agree... i think toyota did some research and develpement work and came up with a good idea that those wire work pretty damn good for that ignition system.
bigger wires allow more current draw thru them to create a bigger spark... bigger spark mean less saturation... no dwell... and you can start buying a new coil every 3,000 miles too...
which is probably your problem now...
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-30-2006, 04:26 AM   #9 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
What is this coil? I know about the cap rotor plugs and wired, but I recently had similar to the same problem... maybe I should order the kit, and some wires.
Zz_005_zZ is offline   Reply With Quote
Old 11-30-2006, 10:10 AM   #10 (permalink)
WHAT!?!?!?!?!?!?!?!?!?!
Old 11-30-2006, 06:18 PM   #11 (permalink)
Audi Technician
ignition coil...
using magnetic fields to induce a secondary voltage which flows thru a wire to your distributor cap... and from you cap to the cylinder needing to be fired...
that one coil sparks for all 4 cylinders and if you increase the damand on it your going to burn it out faster...
coils are like 150 - 250... not by any means cheap
Old 11-30-2006, 06:21 PM   #12 (permalink)
Audi Technician
distributor is just spark timing... something has to produce the spark...
thats why all new cars got rid of the distributor and put one coil per plug... called coil on plug... or coil packs which is 1 coil for 2 plugs...
Old 11-30-2006, 06:32 PM   #13 (permalink)
Young At Heart
:0) thanks... I remember now... been a while since I was in auto mechanics waaaay back in the High School days.
Old 12-01-2006, 10:33 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Toyota calls the coil an "igniter"....go figure and I have had long, dependable use from stock Toyota wires. i wouldn't pay the extra money unless I was making mad HP... Also, if ignition compenents are all in good shape, maybe check O2 sensor.. If bad, will send incorrct signal and make you run really rich...and can cause the bogging and excess fuel you smell.
The Jedi Speeder at CarDomain
Old 12-01-2006, 11:08 PM   #15 (permalink)
Young At Heart
I have just recently discovered somewhat the same problem... Just tonight I was driving back from the track.... (I was just spectating), and I have noticed this b4, however didn't realise it was this until tonight... The car runhs fantastic... all the time, but I have never gunned it from 0 mph until recently... as if to race someone at the track. The car only got 5 psi of bogging boost, then without the bogging, stayed that way for about 15 seconds, then returned to normal 14 psi. It does this every time, but only if trying to race from 0 mph???
I ordered new cap, rotor, spark plugs, and wires... NGK, as I posted in the thread, so if it is an ignition problem let me know... I never reach higher than 5 psi in this situation so it is not the fuel cut. I am really clueless.... but it sounds similar to 430 hp toy's situation.
HELP!!!!
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
94 5sfe KNOCKING, WEIRD PROBLEM profuse007 3rd & 4th Generation (1992–1996 & 1997–2001) 7 08-11-2006 09:49 PM
weird shorting problem, need help tmarsh Camry & Solara Lounge 2 07-30-2006 03:50 PM
Weird Starter Problem shogun6684 Tercel, Paseo, Starlet, and Sera Forum 4 05-25-2005 04:41 PM
Problem with boost decrease Dragons88Supra Supra Forum 15 05-09-2005 10:35 PM
