Acessing the brake light bubls - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2006, 08:14 PM   #1 (permalink)
Owns first Mr2!!!!!
View DjJester88's Photo Gallery
How do I get to the brake light bulbs?! I don't have any brake lights, and also, if its not the light bulb, where is the fuse? Can anyonce give me a step by step? Or atleast post a pic....
DjJester88 is offline   Reply With Quote
Old 11-30-2006, 02:25 AM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
if you have no brake lights on both sides its not your bulbs and maybe a fuse but most likely a mis-adjusted brake switch... or one that either failed or fell outta adjustment
tHa kNiGHt FaLL is offline   Reply With Quote
Old 11-30-2006, 11:31 AM   #3 (permalink)
Owns first Mr2!!!!!
So how would I be able to fix it if its a mis-adjusted brake switch? How would I know it fell out of adjustment?
Old 11-30-2006, 12:21 PM   #4 (permalink)
Owns first Mr2!!!!!
Ok cool! I got them to work....but heres the next problem.....THEY WONT TURN OFF!!!!! AAHHH!!!!!! how the hell do I fix that?! I tried pumping the brakes to see if it worked, even when the car is on and off! PLEASE HELP!
Old 11-30-2006, 06:06 PM   #5 (permalink)
Audi Technician
did you adjust the brake switch.... cause if you did you adjusted them too far...
Old 11-30-2006, 08:37 PM   #6 (permalink)
Owns first Mr2!!!!!
Ok, how do I do that? Like what tool am I suppose to use?!(me=noob)
Old 12-01-2006, 02:25 AM   #7 (permalink)
Audi Technician
look at the brake pedal... push it in... watch as it gets to the floor the upper part of the pedal will push against a switch... the mounting bolts for the switch if you loosen them it allows you to move the switch to adjust it...
Old 12-01-2006, 01:00 PM   #8 (permalink)
Owns first Mr2!!!!!
Thumbs up
OMG!!!! THANKS MAN!!!!!! I GOT THEM TO WORK!!!! YESSSSSS!!!!!!!!
Old 12-02-2006, 12:37 AM   #9 (permalink)
Audi Technician
1996 Corolla Third Brake Light BigTattoo Archived Corolla threads 6 10-23-2005 12:21 PM
3rd Brake Light Blowing Bulbs? rkersh409 Camry & Solara Lounge 0 03-08-2005 07:58 AM
Brake light and turn signals... ai6908 Camry & Solara Lounge 4 03-05-2005 02:27 PM
Gen5 Brake Light VVT-i Owns 5th & 6th Generation (2002-2006 & 2007-2011) 2 08-25-2004 05:01 PM
L.E.D. Tail/brake light & 3rd brake light conversion project eviltwin67 Camry & Solara Lounge 2 07-02-2003 10:24 AM
