Horn not sounding - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2006, 12:03 AM   #1 (permalink)
Owns first Mr2!!!!!
View DjJester88's Photo Gallery
Horn not sounding
Now moving on to the next problem...my horn......its not sounding at all......how do I fix this? Lol, so many problems with my car....but trust me, this car is beautiful.....Ill post up some pix one day so you all can see
DjJester88 is offline   Reply With Quote
Old 12-02-2006, 12:36 AM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
lol... damn...
push the horn and see if the relay clicks or not
tHa kNiGHt FaLL is offline   Reply With Quote
Old 12-02-2006, 11:40 AM   #3 (permalink)
Owns first Mr2!!!!!
If it doesn't click, where do I check for that?
Old 12-02-2006, 10:00 PM   #4 (permalink)
Audi Technician
the actually horn button itself in the steering wheel...
Old 12-02-2006, 10:01 PM   #5 (permalink)
Audi Technician
considering you checked the fuse already
Old 12-02-2006, 11:11 PM   #6 (permalink)
Owns first Mr2!!!!!
Well, how do I acess the button without making the airbag go off?
Old 12-03-2006, 01:55 AM   #7 (permalink)
Audi Technician
lol... damn you gotta remove the air bag assembly...
let me look it up real quick...
Old 12-03-2006, 02:02 AM   #8 (permalink)
Audi Technician
ok...
wheels straight... ignition off... no key... lock the steering wheel.
disconnect the negative of the battery and wait 30 second or more before starting.
using a T30 Torx Bit... T30 is the size... remove the 4 screws 2 on each side of the steering wheel... on the sides... near the turn signal. pull the air bag / steering pad out slowly and disconnect the harness....
the horn button should be visible at this point... according to toyota manual.
Old 12-03-2006, 02:07 AM   #9 (permalink)
Owns first Mr2!!!!!
Question
ok.....once I see it visible, how do I fix it? What do I do with the button?
Old 12-03-2006, 04:22 AM   #10 (permalink)
Audi Technician
there is going to be two contact pieces... the piece you push when pushed will contact another piece closing the circuit allowing the horn to sound...
check to made sure they are making contact when pushed in...
i'm online at random times but if you can catch me on AIM... hit me up again
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
horn diagnosis rasta420 1st Generation (1995-1999) 3 10-09-2006 01:10 PM
Need help with horn install!! wikkd88 Pre-88 Toyota Pickup/Hilux 1 04-11-2006 12:54 PM
No horn / steering wheel basic electrical stilllearning6 Celica Forum 1 03-17-2005 07:38 AM
disable horn confirm alarm arm/disarm hypnotoad Audio, Video, and Security - Tech 4 10-03-2003 05:22 PM
