supra turbo not an upgrade? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2006, 04:44 PM   #1 (permalink)
tamalpro
View tamalpro's Photo Gallery
2nd Generation supra turbo not an upgrade?
i heard like 100 times that i could put a ct26 from a supra, and i called the shop so i could rebuild it and then install it, i told him that i also heard, that i could put the exausth side from MY turbo to the supra one ( better for the doble waste gate), he says, that the down pipe will not fit on the supra turbo, also if i change the waste gate, he says is not better, cause the exausth side of my turbo its smaller than the supra exausth. He says i should just rebuild the turbo and dont change parts. HE says he knows.
OR DOES HE......???
HELP!!!
tamalpro is offline   Reply With Quote
Old 12-08-2006, 06:29 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You can put a CT26 from a Supra where? I am not understanding what you have written...
The Jedi Speeder at CarDomain
Old 12-08-2006, 07:32 PM   #3 (permalink)
tamalpro
where?
where? well, in exchange for the one i have, cause th supra one its a litle bigger, or mix the compresor side from the supra and the exausth side from the mr2, the mechanic says i cant use the supra turbo on my mr2, neither change parts or mix them.he says if i mix them the exausth side of the supra wont bolt to the down pipe.
Old 12-08-2006, 07:33 PM   #4 (permalink)
tamalpro
where?
Old 12-08-2006, 08:06 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
OK, gotcha..I think he's correct
Old 12-09-2006, 03:33 AM   #6 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
are you talking about making a twin sequencial turbo set up...?
or replacing the stock w/ the supra turbo...?
or splitting the turbo... and combining parts...?
tHa kNiGHt FaLL is offline   Reply With Quote
Old 12-09-2006, 04:45 AM   #7 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
he is talking about splitting the turbo into two halves, one side from the supra, and the exhaust side from the mr-2
Zz_005_zZ is offline   Reply With Quote
Old 12-10-2006, 02:58 PM   #8 (permalink)
tamalpro
2nd Generation yup
ok, its understood, so can some body help me?
Old 12-10-2006, 08:53 PM   #9 (permalink)
jdm 2nd gen ftw!
View nepopolus's Photo Gallery
dont get the supra turbo just save up that is hardly any more power...
nepopolus is offline   Reply With Quote
Old 12-11-2006, 07:50 PM   #10 (permalink)
tamalpro
2nd Generation dont?
i already did, i haveit with me, it was 80 bucks with delivery.
Old 12-13-2006, 11:40 AM   #11 (permalink)
tamalpro
and
and... CAN I DOIT? thats been my question all the time
Old 12-18-2006, 07:50 PM   #12 (permalink)
L J
L J's Avatar
View L J's Photo Gallery
depends what you think a good power upgrade is... the supra turbo exhaust side used with the compressor housing and a modified internal wastegate to fit will out flow even the ct27... there was a time slip posted by mr2matt at 12.9 on the 1/4 and blew his motor because he ran out of fuel... now think if he ran out of fuel that mean that turbo hasnt reached the limit yet now has it?
tamalpro- to answer your question the exhaust side bolts up and the center section is the same... the compressor housing and inducer is different... the mr2 housing must be used other wise the supra internal wastegate rod will hit the manifold...
now you tell me which exhaust housing is going to flow more...
even though this is not my picture im doing the exact same setup... a 50trim ct26 with a supra exhaust housing... my downpipe flanges were ordered from BICpreformance.com
L J is offline   Reply With Quote
looking to buy a 88 Supra(california Emissions) chi-toy Supra Forum 3 12-09-2007 08:09 AM
2jz Twin Turbo Toyota Supra Motor Swap nokicell 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-06-2006 01:38 AM
which would u choose 91 mr2 n/a or 88 supra turbo ceracer33 General Discussion 12 10-05-2004 11:37 PM
