Heater Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2006, 11:17 PM   #1 (permalink)
View SGMTurbo's Photo Gallery
Heater Issue
Hey All
My '91 has always had a bit of an issue with the slider for the heat on the dash.
The slider has always gone only half way across and the heat has, as a result, always been a little less than optimal. It simply will only go halfway.
Q. Is this normal? If not, is there an easy way to fix the problem?
(also, where is the amp in the car, needs to be replaced as well)
TIA
SGMTurbo is offline   Reply With Quote
Old 12-15-2006, 02:54 AM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
each speaker has its own factory amp...
and your cable is binding for the heater valve... its pinched or the heater valve itself is stuck...
tHa kNiGHt FaLL is offline   Reply With Quote
Old 12-18-2006, 10:20 PM   #3 (permalink)
Thanks for the info, I'll look into the heater cable issue.
Think I have an aftermarket amp as I located it and there is only one.
I rarely drive the car and as such always seem to have problems with it....never good for a car not to be driven. Should just put it up for sale.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
1988 Camry Heater Cycles Between Heat & No Heat lashby 1st & 2nd Generation (1983–1986 & 1987-1991) 30 12-11-2006 02:29 PM
22R Cold Mixture Heater? bs1231 Pre-88 Toyota Pickup/Hilux 3 05-09-2006 09:47 AM
'89 Camry, odd heater issue chromedragon 1st & 2nd Generation (1983–1986 & 1987-1991) 2 11-30-2005 10:04 AM
heater issue bowlofturtle Camry & Solara Lounge 22 04-28-2005 03:57 PM
