dot 3 for clutch!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2006, 09:47 PM   #1 (permalink)
thangxixon's Avatar
View thangxixon's Photo Gallery
dot 3 for clutch!!
1/ wat u guys use for clutch fluid
i have a mk1 86 and i use dot 3 , same as my brake fluid
2/ i found myself adding clutch fluid every 2 week ( drop from top to half). is this normal? i find out cuz i felt hella hard to shift, and i chek reservoir was empty. i filled up, it ease out but stil
anyone know anyting bout dis.
thangxixon is offline   Reply With Quote
Old 12-18-2006, 01:52 AM   #2 (permalink)
Gameroom cash: $134355
probably your master cylinder leaking into the cab.... happens on early mk1's because the MC's were made of cast, not aluminum.....
Old 12-18-2006, 03:23 AM   #3 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
dot 3 is hydraulic fluid... for a hydraulic system... all hydraulic systems are closed systems.... any loss of fluid is an indication of a leak.
leaks are pretty easy to find... fluid is shooting out somewhere when the clutch pedal is engaged
tHa kNiGHt FaLL is offline   Reply With Quote
Global intersection dot com???? toku58 2nd Generation (2005+) 6 10-08-2006 11:19 PM
the little green dot S92GT Site Suggestions, Questions, and Comments 7 02-24-2005 11:59 PM
ontario driver's license white dot? TOcorolla Off Topic 3 09-15-2004 08:14 PM
Can you find the dot? xpeed Off Topic 7 06-09-2004 05:44 PM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
