flywheels..which is better? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2007, 08:02 PM   #1 (permalink)
View 1quickmr2's Photo Gallery
ok.. i got a 93 jdm turbo in my na. things r leakin pretty so ima do a minor performance build on it. i technically dont have any performance parts on it besides a mbc. but after the this its gonna have a spec stage 1 clutch, fidanza cams, 60-1 ct26 upgrade, manifold and downpipe, and catless exhaust. and this is for a dd car and occasionally runs at the strips.
which flywheel would be good for me, which is better for this setup up. aluminum or chromoly 9.5lbs or 12lbs and does brands matter cause on ebay theres a 10lbs chromoly for 175 or should i stick wid fidanza
1quickmr2 is offline   Reply With Quote
Old 01-29-2007, 07:47 PM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
stick w/ the brand name on this one... a cheap one not typically designed for a 3sgte crank could throw the balance of your engine off... just cause it might bolt up doesn't mean a cheap company did the reasearch and developement high end performance companys do to achieve that product. if they did... it wouldn't be so cheap
tHa kNiGHt FaLL is offline   Reply With Quote
Old 01-30-2007, 12:30 AM   #3 (permalink)
that is true. i will just get the fidanza one.
Old 01-31-2007, 11:04 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Unorthodox Racing makes a beautiful T6 Aluminum 10lb Flywheel. Very well made, but very pricey $$$
The Jedi Speeder at CarDomain
Old 01-31-2007, 11:37 PM   #5 (permalink)
.400 isnt to bad but 330 for fidanza is the better choice unless someone knows another good spot for flywheels
Flywheels help. JetspeedCamry Camry & Solara Lounge 24 03-25-2005 07:21 AM
light weight flywheels I4 to V6 Swap Camry & Solara Lounge 6 06-24-2004 12:36 AM
How much do 3sfe/5sfe flywheels weigh? Talisman 3rd & 4th Generation (1992–1996 & 1997–2001) 10 06-20-2004 02:52 AM
Flywheels and trannys: Aint they a bitch?! spills1969 Camry & Solara Lounge 14 10-11-2003 11:42 PM
