Originally Posted by MR2BAD
Would you be able to get more fuel to the engine that way?
yea... but you can do that w/ a pressure regulator or even bigger injectors...
an ECU will allow full control over mapping which you fully control delivery amount thru out the the power band... pulse widths everything... which is very cool and very beneficial but very very expensive. you don't need it w/ a stock or even moderate street tune.
before upgrading anything you need to find out the actual fuel damands of your motor and then decide what you need.
but he's talking about turbo on a N/A and the management you would need. because its obd I and the fact you can't have high boost do weaker internals especially weaker internals w/ higher compression... fuel and spark isn't a concern of yet... you would need a boost controller and a new map/boost sensor... these are load sensors and tell the ECU how much fuel is required due to a change in load.... small changes like low boost can be handled by the stock set up.
