Distributor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2007, 09:00 PM   #1 (permalink)
Owns first Mr2!!!!!
View DjJester88's Photo Gallery
Distributor
Ok I found out what my problem is with my Mr2.....Its the distributor.....my mechanic told me he'll fix it for 350.....is this a good price?
DjJester88 is offline   Reply With Quote
Old 02-14-2007, 02:25 AM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
too much...
besides you can't fix a distributor... you can replace it or parts inside...
but still R/R the entire thing and setting the timing (which a good tech can R/R w/o messing up the timing) shouldn't cost that much.
get a print out of the estimate and lets see what he's charging you for.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 02-15-2007, 03:47 AM   #3 (permalink)
View mr2poweraw11's Photo Gallery
i noticed from another thread you got this repaired, but for future references, i had this problem also, a distributor alone can cost from 40$ used to 150 rebuilt, depending where you get it. its a, wel, hassle to take off the distributor on a aw11 because its impossible to see the screws, if you have alot of patients you can probably do it. I had a swapped done and my mechanic installed the rebuilt distributor for free because teh engine was already off.
mr2poweraw11 is offline   Reply With Quote
Old 02-17-2007, 08:49 PM   #4 (permalink)
Gameroom cash: $134355
aw11 dizzy's are easy to r/r.... the HARD part of it is making sure you have the teeth aligned right as the shafts aren't offset like toyota FE head dizzy's are....
Old 02-20-2007, 01:57 PM   #5 (permalink)
Once upon a time...
View kbox's Photo Gallery
So what exactly is wrong with the distributor?
Jody Collicutt - [color=blue]'87SC J-Spec DLI AE92 - 246,246 kms and counting...
kbox Engineering www.kbox.ca
kbox is offline   Reply With Quote
Distributor O-ring replacement, and yes I searched 87Camry5Speed Camry & Solara Lounge 13 12-15-2011 11:50 PM
Question about install of new Distributor Cap & Wires elka Hardcore Tech and Competition 3 09-11-2006 02:06 PM
93 Celica Timing Belt + Distributor Is the Shop telling the truth? jamesbrogdon Celica Forum 16 05-03-2006 05:44 PM
95 5SFE won't start - a question re: distributor 500KCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 36 04-19-2006 08:13 PM
