5S-FE has a weak head...? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2007, 05:32 AM   #1 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
front wha i just heard... 1jz... valves/springs and retainers are a direct replacement allowing more flow...
i'm just throwing this out there... i haven't done any research on it yet... but i've heard it from multiple sources which to me makes it worth researching.
i mean.... aslong as it seats on compression.... why not... you can get 1jz valvetrain from a junk easily.
imma have to check in on this... nice cause cali CHP can't see this...
tHa kNiGHt FaLL is offline   Reply With Quote
Old 02-18-2007, 04:48 PM   #2 (permalink)
mr2oogleX
View moogleX's Photo Gallery
for modding a 5s-fe? my engine needs some work done, been debating on what to do, fix and mod up the 5s, swap 3s etc.
before i spend the money to swap, how much diff does the hard-top vs t-tops really make? my friend rants on and on about hard tops structureal rigidity being a HUGE factor. i understand his point, but i dont think its that big of a deal less your hardcore track racing or something. any thoughts?
moogleX is offline   Reply With Quote
Old 02-18-2007, 05:05 PM   #3 (permalink)
View 91MR2quickNA's Photo Gallery
The 1JZ was never offered in the U.S., but yes, the 2JZ valves fit the 93+ 5SFE head, and the 3SGTE valves fit the 90-92 5SFE head. Either are 1mm oversize.
You should really only consider this after you've already done cams and headers. It complements both. Some port work helps too.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 02-18-2007, 05:10 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
It's somewhat a factor, but I wouldn't call it a major one. there are other ways of sureing up structual integrity. Jeff Fazio (Jeckyl and Hyde Racing)has a T-Top and he's using it for hill climbs-and setting some records on top of that. Given that, I would say it's negligible...
The Jedi Speeder at CarDomain
Old 02-18-2007, 06:43 PM   #5 (permalink)
Audi Technician
that much is obvious...
i thought the 1jz was the second gen supra... the 6 w/ the single turbo...
anyways i read it correctly... maybe they had it wrong.
but its always nice to see performace options for the 5S-FE
PART 1: 3S heads revised allblackalltrac Hardcore Tech and Competition 4 01-15-2007 04:49 AM
What will be needed for GE head on FE? Kr0n1k Archived Corolla threads 25 10-08-2006 01:08 PM
3VZ FE Head Removal scprandy Camry & Solara Lounge 5 01-16-2006 02:32 PM
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
