need some help with maintenance stuff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2007, 01:01 PM   #1 (permalink)
View Itech's Photo Gallery
Ok so I just got a 5k signature service from my dealership and the list of repairs are huge... seeing as all the numbers are huge I want to know what I should be able to easily do myself that isn't too bad if I mess up.. or if I don't really need it.
Oil Pressure Switch (Broken)
Valve Cover Gasket Leaking
Main seals Leaking
Clutch Slipping
Front Brakes down to 3mm
Ok as for the clutch and brakes... How long do clutches usually last? Front brakes they quoted me 465 to do the both fronts with new pads and new rotors. I was wanted to do a brake upgrade but not loose my ABS or anything. Car is N/A. Can I go to a junkyard to find a good pair of Turbo Brakes and do an upgrade? Would that just directly bolt on?
Thanks
Car is a 1991 MR2 N/A if that info was needed
Itech is offline   Reply With Quote
Old 02-19-2007, 01:16 PM   #2 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
Gameroom cash: $489401
View falnfenix's Photo Gallery
clutches and brakes are both wear items, and their life depends entirely on the driver of the vehicle. you can ask that question and get answers all over the board.
ಠ_ಠ
i don't play well with others.
falnfenix is offline   Reply With Quote
Old 02-19-2007, 01:47 PM   #3 (permalink)
TACO FTW
Location: Norton Shores, MI / Houghton, Michigan (MTU) FTMFW
View 92_Gen3_5SFE_LE's Photo Gallery
yes clutches can last 200k + or as little as 0miles I saw someone do that, all the pretty smoke
92_Gen3_5SFE_LE is offline   Reply With Quote
Old 02-19-2007, 02:02 PM   #4 (permalink)
Wow okay... I also ment to post this in the MR2 section... I was browsing both the offtopic and MR2 part and I guess I posted it in the wrong section Can a mod PLEASE move this post so I can get some better feedback? thanks
