oil pressure light.. help me think - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2007, 02:14 AM   #1 (permalink)
View bowlofturtle's Photo Gallery
Its been a while since i touched a toyota but i'm looking to buy a car and most cars are the same, looking to see if i'm overloooking in some areas or not.
$500 gets me a 91 white mr2. with 170k miles and oil pressure light being on.
He told me all of a sudden oil pressure light came on and he took it to a mech. and they told him 1700 for new engine and he left and is selling.
first off i'm assuming it is a 5sfe, I'm thinking oil sludge at most. But the easy stuff first possible oil pressure sens bad, oil pump screen clogged, oil pump failing are my thoughts. I thinking if it aint a easy fix its time to throw in an engine either 2.2 or the turbo. Anything i forgot bout the 5sfe to make this a non-so common problem?
1. oil level
2. oil leaks
3. oil sensor
4. oil pump
5.sludge
I kinda ruled out #1 AND POSSIBLE #2/3 since a mech looked at it. but then again he might try to sell him junk. He told me it was on solid and thats all i got from him as he was in a rush. More info morrow. Just wanted to look at this with a clear thought on what to target more or less
96 Camry Le I-4
bowlofturtle is offline   Reply With Quote
Old 02-21-2007, 02:30 AM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
theres an oil pressure light...?
check the oil pressure yourself... get a gauge for like 30.00 and check it out yourself...
a manual gauge will not lie to you... you need to figure out if its low oil pressure... or no oil pressure.
low oil pressure could be a bad pump... or most likely worn bearings.
no oil pressure could be a broken drive shaft for the pump... or spun bearings...
usually a tech should tell you why... you need a new engine
tHa kNiGHt FaLL is offline   Reply With Quote
Old 02-21-2007, 02:55 AM   #3 (permalink)
as of now, i dont know what the tech told him. I figure the 1700 scared him into selling it.
I' m looking to buy and fix problem or swap.
96 Camry Le I-4
Old 02-21-2007, 08:49 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
For $500.00 I would buy the car and fix it no matter what the problem was. Either repair, rebuild or put in another engine...It would be worth it. Even if you spent 4-5K, you would have a good 2 !
The Jedi Speeder at CarDomain
Old 02-22-2007, 03:54 AM   #5 (permalink)
Audi Technician
you could part it out stock and easily make twice that.
i could use a few interior pieces myself... it being white.... so most likely blue interior. definately send some shit my way
Old 02-22-2007, 06:28 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
yeah, you could do that.. But I thought he wanted an MR2...
Old 02-22-2007, 01:24 PM   #7 (permalink)
View idae86's Photo Gallery
what about the oil pickup. It could be out of adjustment causing it to not get the right amount of pressure causing the light to come on. I dont know toyotas to well but i know on hot rods and what not that is normally the issue that cause low or no oil pressure.
idae86 is offline   Reply With Quote
Old 02-22-2007, 01:25 PM   #8 (permalink)
i dont know if thats the right name for it but the unit the sucks the oil in is what im talking about.
Old 02-22-2007, 09:10 PM   #9 (permalink)
View OEMonkey's Photo Gallery
bowloft,
verify first if it is indeed the oil pressure light that is lit.
On MKII Turbo cars (and maybe on non-turbo as well), there are 2 oil lights. 1 under the temp gauge - red oil can, this is the oil pressure light. 1 under the trip odometer reset button - amber oil can w/ squiggly line below, this is the oil level light. So if it's just the amber light that is lit, oil level is low or there is an open on the sensor. Most people break the oil level sensor when re-sealing the oil pan. The sensor needs to be removed(snaked out carefully) before dropping the pan, otherwise you break the sensor when you remove the pan. It gets caught on the pick-up, breaking the float.
OEMonkey is offline   Reply With Quote
Old 02-23-2007, 06:03 AM   #10 (permalink)
Audi Technician
yea... i was agreeing w/ the fact for whatever its worth... 500.00 is worth any sw20 doesn't really matter the condition
Old 02-27-2007, 06:17 AM   #11 (permalink)
MuMan's Avatar
View MuMan's Photo Gallery
bump
Nothing is Forever
MuMan is offline   Reply With Quote
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Oil pressure light okiesteve Archived Corolla threads 4 07-18-2006 12:06 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Oil Pressure sensor/switch lcarocha General Discussion 1 07-06-2005 05:22 PM
