Originally Posted by idae86
Hey i wanted to do a 4age20v with the 4agze supercharger. But my ? is stock, what is the psi the the supercharger and im going to need the crank pulley from the 4agze motor on the 4age20v, and if i wanted to up it where can i get those pulleys to do so. All i really want to push is 7psi 8 max. I just want it for the low end power and torque. Thx guys.
if you kno what the static compression ratio i can figure out the max boost for you, before problems... at what PSI you have to run better fuel...
theres a formula for it...
