Master Brake Cylinder - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2007, 04:12 PM   #1 (permalink)
View Itech's Photo Gallery
IS there a difference between n/a master brake cylinder and the turbo one. I see lots of people doing the conversion on the front to the 2piston calipers.. But then does the n/a master brake cylinder hold enough fluid to push those calipers?
Itech is offline   Reply With Quote
Old 02-22-2007, 04:37 PM   #2 (permalink)
View toyomoho's Photo Gallery
Might check someplace like www.rockauto.com to see if the part numbers for your cars setup are the same as the turbo model.
100 series brake master question Pdawg General Discussion 2 02-08-2007 04:55 PM
Brake Problem...master cylinder or booster? Not sure... 87_SR5 Pre-88 Toyota Pickup/Hilux 6 11-18-2006 07:02 PM
Brake Problem.. Can any one suggest? Babar Archived Corolla threads 1 10-28-2006 08:04 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
