Originally Posted by Zero turbo
no its not me its a tuner but i am going to do a full turbo kit upgrade with a t3/t4. But how much psi can i push with a t3/t4 turbine .50 trim before i get the full fuel upgrade i whant to put the turbo and run it in a SAFE boost. I was thinking of like 8 psi of course i will get a IC before putting the turbo...
theres a formula to finding out what turbo is best for your engine...
It goes like this:
2.0 Liters = 122 CID (cubic inch displacement)
Your P/R (Pressure Ratio) for a desired 8psi is 1.54
Now you need to find out the engine's CFM (Air Flow Rate)
The formula is :
CFM = CID x Redline (Max Power) x VE (Volumetric Efficiency) x P/R
Divide By 3456 and you get
CFM
So for a
2.0L 3SGTE Turbo Motor
122 x 6000 x .9 (90% VE) x 1.54 = 1014552
Divided By 3456 = 293.5625 Rounded up is
294 CFM
Now you need to find out CFM per minute for MAX and LOW RPM.
(CFM Divided By 14.7 = LBS/Per Min)
So 6000 Rpm = 20 lbs/per min
3000 Rpm = 10 lbs per min
CLICK ON PICTURE FOR CLOSE UP
This is your car... mapped out on the T3/T4 Hybrid w/ .50 Trim
As you can see the pressure ratio is low... So w/ this turbo your gonna need to boost more than 8 psi for it this turbo to make any real power.
To get a 2.0 P/R you need to boost
16psi... for this turbo to function properly on your car.
3SGTE has a static compression ration of 8.8:1 so w/ 8psi you'll have an effective compression ratio of 13.5:1
w/ 16psi you'll have an effective compression ratio of 18.3:1
These numbers are actual to your car... so i'd go w/ fuel management system and give these numbers to your tuner. and he'll be able to tune safely
