Synchros - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2007, 03:32 PM   #1 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
Synchros
I am thinking about doing the tranny synchro's at the same time that I am doing the stage 2 clutch, 9.5 lb. flywheel, and rear end seal... any ideas on the price??
Zz_005_zZ is offline   Reply With Quote
Old 02-23-2007, 04:01 PM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
they will come in a trans rebuild kit... cause when you break open the case you got some seals to change.... i've seen em around 300.00 for the entire thing.
check w/ toyota and then maybe autozone... and lastly check w/ a trans shop.
you should get three different prices... and three different qualities...
toyota being best, then trans shop and lastly always your local parts store
tHa kNiGHt FaLL is offline   Reply With Quote
Old 02-23-2007, 06:28 PM   #3 (permalink)
jdm 2nd gen ftw!
View nepopolus's Photo Gallery
heh...i need one of these to my 2nd gear sucks..i diddent know they are that cheap, but i dont know how to fix transmissions so labor will be a ton....mabe i will just get that new lsd trans and axles
nepopolus is offline   Reply With Quote
Old 02-23-2007, 07:47 PM   #4 (permalink)
Audi Technician
a manual transmission is very very easy... break open the case and there are three shafts...
gotta remove all the gears to change out sycros... just mark them all for position... be precise... to where each gear goes on the shaft. just make sure sycros and gear all face the right way and depending on the type of sycro (brass, paper, etc) pay attention to install details... like if they want them prelubed, installed wet, installed dry.
its pretty easy
Old 02-25-2007, 04:15 PM   #5 (permalink)
jdm 2nd gen ftw!
hmmm.....i do have a extra 5sfe trans, i think i am gunna see if i can pull that apart and make it shift good still then see if i can do it to my 3sgte.
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
replacing synchros? estimate? TdotTercel General Discussion 1 07-11-2006 06:56 PM
Clutch??? Synchros??? All I hear is grind thetailwind MR2 Forum 15 10-11-2005 04:23 AM
dual cone synchros chris93473 General Discussion 4 03-09-2005 10:46 AM
shot synchro's GTSR5Corolla Celica Forum 3 12-30-2004 01:00 PM
