URGENT Help - Speedo - Electronic to Manual - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2007, 08:26 PM   #1 (permalink)
View moberman's Photo Gallery
I am transplanting a late Gen-3 3S-GE setup into my 90 SW20. I can connect the speedo cable, but want to know what the effect will be if I do not connect the electronics from the box to the computer.
Has anyone done this before? Will the computer misbehave if it doesn't the speedo feed? What is the best way to deal with this (short of rewiring to put in an electronic speedo in the dash)?
Your urgent responses are greatly appreciated.
moberman is offline   Reply With Quote
Old 02-23-2007, 08:36 PM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
Speedo cable...?
Vehicle speed sensor...?
Does it have ABS...?
tHa kNiGHt FaLL is offline   Reply With Quote
Old 02-23-2007, 08:39 PM   #3 (permalink)
Audi Technician
and wha box...?
speedo cable goes from trans to instrument cluster
Old 02-23-2007, 08:43 PM   #4 (permalink)
Thanks for your quick response.
My mechanic is doing the work so sorry for being vague. I suspect I do not have ABS, but as I am replacing an old 3S-GE engine, gearbox, exhaust, air intake, wiring harness and computer, with the new (I think 1998 version) kit, I think the mechanic can connect the current (manual) cable to the box, but he is unsure if there is any impact not connecting the electronic speedo connections from the box to the ECU.
Your help is appreciated.
Old 02-23-2007, 08:51 PM   #5 (permalink)
Audi Technician
O I C...
I get it... you have a manual speedo cable system and the new setup is electronic or VSS...?
you said he can connect the cable... which i don't get cause if it was a VSS setup there would be no connection on the trans for a cable... just wires going to the ECU and Cluster.
Anyways w/o further info i can't help you fix the problem but wha i can say is...
you will still be able to drive this car safely... just your speedo isn't going to work and it will most likely throw a code that you have low VSS circuit voltage.
Old 02-23-2007, 08:59 PM   #6 (permalink)
Again, thanks for your quick response.
My mechanic says he can replace the electronic output on the box, with the mechanical setup, and thereby connect the cable at that end. His question is whether not connecting the electronics to the ECU will have an impact. Does the Gen3 ECU need or use this electronic input for anything?
Really appreciate your assistance.
Old 02-24-2007, 02:24 AM   #7 (permalink)
Audi Technician
why doesn't he keep the electronic output from the new trans and hook that up to the new ECU...?
in that case your only problem is no speedo... so all you need to buy is a 93 speedometer w/ VSS.
if not... your computer won't read VSS signal and throw a code. but you can drive it wi/o damaging anything.
Old 07-26-2007, 11:11 PM   #8 (permalink)
Danno
View 89yotarollagts's Photo Gallery
Sorry to thread jack, but i have a question that fits into this as well... Im transplanting a ae101 4agze into my ae92 the ae101 has an electronic gauge whereas my ae92 is run by a cable... i was told to get the part of a 91 mr2 turbo, What can i do to get my speedo back ?
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 07-28-2007, 12:05 AM   #9 (permalink)
boost > vtec
View MRtuned's Photo Gallery
won't this also get rid of the speed limiter??
you can't just plug in a newer gauge cluster. you need to rewire the whole front of the car.
gen 3 3SGTE swap, manual conversion, HKS Turbo exhaust, Blitz intake, TRD short throw shift kit, Autometer Boost gauge, OBX manual boost controller, Walbro 255lph fuel pump, 93+ rear suspension and subframe, Turbo model brakes
MRtuned is offline   Reply With Quote
speedo problem tjyota 4Runner Lounge 0 05-24-2006 12:15 PM
Correcting speedo error: will 265's fit? Activator 2nd Generation (2005+) 4 11-17-2005 07:46 PM
Transplant auto to manual roscoa1 Supra Forum 5 05-18-2005 12:10 PM
no manual transmissions in the 1980's??? evilinside Archived Corolla threads 1 03-28-2005 01:23 PM
Broken Speedo, Help? Slip_87 ST Celica Forum 3 02-19-2005 03:34 AM
