crankshaft question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2007, 10:52 PM   #1 (permalink)
View 91MR2NASTL's Photo Gallery
crankshaft question
so i have a nonturbo 5sfe mr2 that the engine finally gave. my buddy is gonna sell me his mr (3sgte turbo model entire car with leather and a few mods, but the car has a few body problems was wrecked twice). the bad, is that it had recently had a flywheel and clutch installed and the flywheel wasnt torqued down properly, so the crank is just screwed. Would it be cheaper to buy a rear clip (around 2500 or so) or to buy this car (which would fix every little problem with my car and upgrade to all leather) for 1000, and rebuild the engine. how much does a crank job usually go for? thanks
91' MR2 5-speed N/A, hopefully soon 3sgte!
91MR2NASTL is offline   Reply With Quote
Old 02-25-2007, 11:09 PM   #2 (permalink)
jdm 2nd gen ftw!
View nepopolus's Photo Gallery
if you have money get your 5sfe crank redone and hardend and get that 3sgte board to a 2.2 ltr
nepopolus is offline   Reply With Quote
Old 02-26-2007, 12:41 AM   #3 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
how much for the car...?
you could just put the 5sfe crank in the 3sgte
tHa kNiGHt FaLL is offline   Reply With Quote
Old 02-26-2007, 12:58 AM   #4 (permalink)
im going to either fix the engine in his car (it needs a new crank) and put that engine in my car (since mine has a much better body). OR im going to just buy a half cut and put that in my car. Im just not sure how much a crankshaft job is.
If its a lot cheaper to just get a half cut, then ill do that, but otherwise id like to rebuild his engine and use it as a donor car for mine, so i will have a whole new interior and fix a bunch of minor things like my ebrake, heater, window, and all will get replaced by the new one.
hes sellin the parts car for 1000 bucks. half cuts go for around 2500.
Old 02-26-2007, 03:25 AM   #5 (permalink)
mr2oogleX
View moogleX's Photo Gallery
crap, if i had 1000 bucks id buy his car
we have any pictures of it? what other work needs to be done to his car?
Originally Posted by Quandry
...Turbo's have vaccum too, it's just not the fun part of the gauge
moogleX is offline   Reply With Quote
Old 02-26-2007, 09:01 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Buy the turbo, cannibalize it for what ever you need . it's worth $1,000.00 just for the engine and all the parts...
The Jedi Speeder at CarDomain
Old 02-26-2007, 09:18 PM   #7 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
It's hard to say without seeing the car, but I can't imagine that it is not worth $1000.
Seeing as you are interested in costs, I would not recommend going
the route mentioned above of using your 5SFE crank in the 3SGTE.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 02-26-2007, 09:38 PM   #8 (permalink)
yah im defiantly not using any 5sfe parts, the engine had close to 300k on it. does anyone know how much a crank job is in a 3sgte rebuild? and the best place to get a new crank? i hear that its best to go to the dealership just because they are more reliable? i just want to basically use the parts car for its engine and components to convert mine to a turbo. but i have to rebuild that engine first.
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
2007 Camry Question skippy126 5th & 6th Generation (2002-2006 & 2007-2011) 5 05-24-2006 07:47 PM
Oil pan question? White89SR5 Archived Corolla threads 4 10-07-2005 06:14 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
NEED HELP: Timing Belt Marks Question turbox2k Camry & Solara Lounge 1 08-16-2005 12:06 PM
