you need to find out your CID (Cubic Inch Displacement)... cause you changed your compression ratio its going to be different from stock.
http://www.csgnetwork.com/cubicinchdispcalc.html
From there you can calculate CFM and from there you can search the internet for compressor maps and plug in you info and it will show you how your motor will respond to each.
you can just guess... but i figure since you have to make a custom manifold your gonna want one that you can maximize its potential. and there are percise ways of finding it out.
if you need help, just post the CID you find out and i'll calculate the rest and input it on a sample compressor map and you can search from there.
cause you don't want it to big to where it doesn't boost right cause it exceeds the surge limit line, or your motor doesn't move enough air to properly boost a big turbo. or comes into efficency too early and runs out at top end... or too late and never reaches its potential cause the motor is too small.
but then you need to decide wha RPM range you want the turbo to start coming into efficiency...
its all possible, but requires a lil research
