Originally Posted by jesse0880
i was told that MAF sensors can be cleaned. but this came from a mech that mostly just works on ford stuff... is this also true with my deuce MAF sensor?
yes... there is three kinds of MAF in all cars.
all others are self cleaning, the Vane Type which the MR2 has you have to clean yourself.
be careful what you use to clean it. You don't want to damage the Intake Air Temp Sensor which is in the MAF housing.
you can remove the potentiometer covering on the backside and check the resistance strip. see if it has a glazed or worn type of hot spot.
