routing gauge lines - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2007, 12:50 PM   #1 (permalink)
View jesse0880's Photo Gallery
routing gauge lines
what is the best form of routing gauge lines from the engine compartment to the driver compartment? i need to install a boost gauge i'd like to know the tips before i start. thanks
p.s. i dont have a gauge cluster or anything so i'll probably mount the gauge somewhere temporarily for now.
jesse0880 is offline   Reply With Quote
Old 03-04-2007, 02:31 PM   #2 (permalink)
View carcrazykid's Photo Gallery
well, give me a day or two and i'll post up some pics of how i made my custom cluster, but for now, this is how i routed the wires for 6 gauges
ok, on the firewall behind the drivers side seat, there is a huge rubber grommet, i routed all of my wires through it, along the back of the wall (under the carpet), and kept it all neat and tidy by tuckin them into the original conduit that runs alongside the shifter, slide the wire to the left of the climate control unit, above the stereo and mount it there in the center piece, or slide it into where the cluster used to be
Or, thru that grommet in the firewall, down the back wall, along the doorsill (all under the carpet) , and up to the A-pillar... those are just the most standard ways
anywho....cleanliness is next to godliness
peace out and good luck
Corey
carcrazykid is offline   Reply With Quote
Old 03-04-2007, 05:35 PM   #3 (permalink)
thanks a bunch man. im actually starting on that project today and that info defintly helps... 6 gauges! ur cockpit must look intense.
Old 03-04-2007, 07:38 PM   #4 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i drilled my own hole through the rear firewall. i installed a really nicely sealing grommet. i used copper tube to run my vac source for the boost gauge. on either end, i used brass unions and then used the nylon hose to go to the manifold (on one end) and then to thegauge on the other end. the copper tube is nice since i ran it down the center console on the side of the shifter cables.
ToyotaTechGeek is offline   Reply With Quote
Old 03-04-2007, 08:53 PM   #5 (permalink)
copper tub huh?... i didnt even think that. i noticed it gets pretty hot in the engine compartment. will i need to worry about damage to the regular vacumm line that i use for the boost gauge?
Old 03-04-2007, 10:57 PM   #6 (permalink)
no, not really unless it kinks badly or gets too close to exhaust
Old 03-05-2007, 05:49 AM   #7 (permalink)
Fist of the North Star
View Komodo's Photo Gallery
I went with electrical gauges and pulled the wires through the existing grommets.
Komodo is offline   Reply With Quote
Old 03-05-2007, 08:03 AM   #8 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
^ That's the best way to go. Running vac lines into the cab can be a pain in the ass in the long run.
Old 03-05-2007, 07:50 PM   #9 (permalink)
Old 03-05-2007, 07:52 PM   #10 (permalink)
its hard to make out, but run your wires along that original loom....the guy that had to wire something up after you would love you for it.....and yes, go with electrical, no vacuum tubing
heres my cluster at night
Old 03-05-2007, 07:56 PM   #11 (permalink)
and since you said you dont have a cluster, i can show you how to build the one i have, it took me a weekend, and was super duper cheap to make
Old 03-05-2007, 08:10 PM   #12 (permalink)
i like the 'real' reference.
Old 03-05-2007, 10:09 PM   #13 (permalink)
geez, lay off, i appreciate the "real" sarcasm...he said he didnt have a cluster...
Old 03-05-2007, 10:28 PM   #14 (permalink)
whateverz
Old 03-06-2007, 01:12 AM   #15 (permalink)
that looks awsome... but i do think the mechanical gauge is gonna be a pain cause wouldnt the vacumm hose get pinched somewhere throughout the distance of the cabin and engine bay?
Coolant Gauge nasty87supra Supra Forum 6 05-04-2007 06:12 PM
8 gauge to 4 gauge? Frugle Audio, Video, and Security - Tech 23 04-18-2006 11:23 PM
hooking up autometer gauge jerryb78 Cressida Forum 2 03-20-2005 09:57 AM
Gen. 2 V6 gauge cluster question xavior66 Camry & Solara Lounge 10 08-09-2003 05:38 PM
