camshafts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2007, 08:02 AM   #1 (permalink)
View K'tara's Photo Gallery
camshafts
I dont really understand the difference between each of these intake and exhaust camshafts that HKS has. So, I was wondering if anybody can help me out?
http://www.andysautosport.com/toyota...camshafts/hks/
Which is best for street and racing use?
K'tara is offline   Reply With Quote
Old 03-05-2007, 08:05 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
what other mods do you have??...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 03-05-2007, 10:07 AM   #3 (permalink)
ATS stroker block, T3 turbo for now, doing the whole head work.
Old 03-05-2007, 10:52 AM   #4 (permalink)
theres a good discussion on the main board about HKS cams..
http://www.mr2oc.com/showthread.php?t=94097
91 mr2..07 335i..
Old 03-05-2007, 04:26 PM   #5 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
your cam profile is the single most important mod you can make to a motor
these cams only show there lobe lifts and durations...
and there are more things to consider then those two. I'd email HKS and ask for spec cards for all those cams. or call them and ask for tech support. give them your motor specs now and what you plan to get w/ cams and they should guide you in the right way.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 03-06-2007, 08:11 AM   #6 (permalink)
I talked to a guy at ATSracing and he pointed out for me to use the 264's with the stroker.
With that out of the way, now I ask what company would yall recomment for valves and what kind of angles should I get on the vavle job?
Old 03-06-2007, 05:20 PM   #7 (permalink)
boost > vtec
View MRtuned's Photo Gallery
get a 3 angle valve job. it allows a decent ammount of contact surface between the valve and the seat so that is seals well, yet is angled away a little bit on either side of the contact surface for better flow.
gen 3 3SGTE swap, manual conversion, HKS Turbo exhaust, Blitz intake, TRD short throw shift kit, Autometer Boost gauge, OBX manual boost controller, Walbro 255lph fuel pump, 93+ rear suspension and subframe, Turbo model brakes
MRtuned is offline   Reply With Quote
Old 03-06-2007, 08:36 PM   #8 (permalink)
Audi Technician
.264 is a nice set...
now you should get the head bench tested for flow...
tell them the cam setup you have
they'll let you know how much CFM can be increase w/ a certain valvetrain
4agze camshafts GraphiteRolla Archived Corolla threads 6 03-30-2006 12:28 PM
Performance & Racing Camshafts...question RichieRichJP Camry & Solara Lounge 15 11-03-2005 09:25 PM
Camshafts Consynx MR2 Forum 14 01-08-2003 02:49 PM
