load sensors???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2007, 07:00 PM   #1 (permalink)
View jesse0880's Photo Gallery
load sensors????
i was reading an earlier post and a guy with the same problem as me brought up checking "LOAD SENSORS", such as the MAF sensor. What other load sensors are there?
other than moving the needle on the gauge, what other role does the turbo pressure sensor play? A/f ratio adjustment or anything like that?
also the same question for the T-VIS. i know it doesn't move the gauge but what is its purpose? thanks
jesse0880 is offline   Reply With Quote
Old 03-06-2007, 08:28 PM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
the boost gauge is a load sensor.
mass air flow sensor is a load sensor.
there are more, but not on OBDI cars.
load sensors have direct effect on A/F ratio....
tHa kNiGHt FaLL is offline   Reply With Quote
Old 03-07-2007, 05:26 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The boost gauge does not have an effect on the A/F ratio.
Sorry, not familiar with that term.
On the Gen2 engines (the ones that came in U.S. turbo MR2s, the MAP sensor just controls fuel cut and the stock boost gauge. It does nothing with A/F.
On the Gen3 3SGTE engines, it is used for determining fueling.
The T-VIS blocks 1/2 of your intake valves (one on each cylinder) so you have more low-end torque. As your rpms build, the TVIS opens so all 8 valves are open and you can flow more air.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 03-07-2007, 07:46 AM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
another question for you guys...i'm not using stock ecu now...is there still a way i can connect my factory boost guage to still work??...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 03-07-2007, 07:48 AM   #5 (permalink)
I love Cin
I am not aware of anyway to do that - sorry.
Old 03-07-2007, 09:17 AM   #6 (permalink)
when the T-VIS opens up those secondary valves (runners), is it possable to hear it like v-tec for hondas? just wondering cause my problem is in the 4000 rpm range?
Old 03-07-2007, 09:20 AM   #7 (permalink)
I love Cin
I've never actually paid attention to whether or not I have heard it ... regardless, I ahven't had TVIS in years.
sorry.
Old 03-07-2007, 09:36 AM   #8 (permalink)
boost > vtec
View MRtuned's Photo Gallery
why would you want to?? that is the most worthless boost gauge ever. just get a mechanical autometer boost gauge.
gen 3 3SGTE swap, manual conversion, HKS Turbo exhaust, Blitz intake, TRD short throw shift kit, Autometer Boost gauge, OBX manual boost controller, Walbro 255lph fuel pump, 93+ rear suspension and subframe, Turbo model brakes
MRtuned is offline   Reply With Quote
Old 03-07-2007, 09:38 AM   #9 (permalink)
I love Cin
Because having the stock gauge standing up at full boost all the time is annoying/distracting to see. I always think something is spiking or overheating or something nasty.
I am pretty sure he already has a good boost gauge.
Old 03-07-2007, 10:58 AM   #10 (permalink)
^^dead on...i just dont like how it looks non functional...
91 mr2..07 335i..
Old 03-07-2007, 12:50 PM   #11 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
I know a lot of people either throw a voltmeter from an NA in or stuff Omari gauge in there.
Old 03-07-2007, 01:46 PM   #12 (permalink)
if i ever pull out my cluster..i will put a shift lite in there if it'll fit....
91 mr2..07 335i..
Old 03-07-2007, 02:55 PM   #13 (permalink)
Audi Technician
sorry... misprinted... boost sensor / map sensor
Old 03-07-2007, 02:59 PM   #14 (permalink)
Audi Technician
absolutley... t-off the boost sensor and run directly to the boost gauge.
Old 03-07-2007, 03:03 PM   #15 (permalink)
I love Cin
That is still incorrect as I explained in the rest of that post:
"On the Gen2 engines (the ones that came in U.S. turbo MR2s, the MAP sensor just controls fuel cut and the stock boost gauge. It does nothing with A/F.
On the Gen3 3SGTE engines, it is used for determining fueling."
The factory boost gauge is an ELETRONIC gauge, not a MECHANICAL gauge.
T'ing into the boost sensor will not operate the OEM gauge.
It does not have a boost/vac line running to it ... that is the whole reason there is a sensor in the engine bay. It sends an electrical signal through the ECU.
Tire Pressure Sensors IndiBlue4x4 2nd Generation (2005+) 4 04-08-2006 07:41 PM
***attention force fed cars with afr sensors gman240 Camry & Solara Lounge 0 10-26-2005 03:51 PM
A/F Sensors Replacement rohlal Camry & Solara Lounge 4 12-20-2004 11:42 AM
JDM sensors ?'s 5Sfte MR2 Forum 6 08-12-2004 04:24 PM
O2 Sensors DrtySthV6SE Hardcore Tech and Competition 4 12-13-2002 10:44 PM
