wastegate question? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2007, 02:26 AM   #1 (permalink)
View jesse0880's Photo Gallery
wastegate question?
is there a special procedure for pressing the valve seat into external wastegates or should u be able just to seat it in by hand? after torquing the wastegate to the flange, the gasket still leaks, and its a new gasket. (I cant get the valve gasket to seat flush into the wastegates surface).
jesse0880 is offline   Reply With Quote
Old 03-09-2007, 08:45 AM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
What brand wastegate? I know my friend has a lot of problems with the Tial sealing on his car. Seems like he is replacing the gasket quite often. Do the surfaces on both sides look flush? Maybe a problem with warping?
Old 03-09-2007, 09:07 AM   #3 (permalink)
its a TIAL 38mm. would u happen to know if your friend has tried using two gaskets instead of one? thats what im thinking about trying because iv cleaned both surfaces and everything so i just dont understand????
Old 03-09-2007, 02:30 PM   #4 (permalink)
Wasnt Me!!
View deuce93t's Photo Gallery
that is why i love my internal wastegate!! I know that there isnt tuning things that you can do that i cant but i dont have near the problems that my friends have with their externals.
deuce93t is offline   Reply With Quote
Old 03-09-2007, 05:30 PM   #5 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
internal WG is okay if your at stock levels...i had major boost creep with mine...zero issues with my ext HKS WG now...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 03-09-2007, 06:27 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I gotta agree with Russ.. maybe 1 or both surfaces aren't flat.. can you get a straight edge on both contact surfaces, criss cross it and see if it's flat? The double gasket could work...
The Jedi Speeder at CarDomain
Old 03-10-2007, 01:47 PM   #7 (permalink)
WEIRD... the day i put the wastegate on and had the leak, i drove it around the block to see how bad it was really leakin ( i based is off my boost gauge which read about 7 psi). I did this because i was hoping through some crazy form of god or thermal expansion the gasket would automatically seal. well, today i fired it up and i couldnt feel any leak and and when i drove it, it boosted all the way to 10 psi. what do u guys think?
Old 03-10-2007, 06:55 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
HHHmmm?what do you mean by " feel any leak"? You mean with your hand? or from driving it?
What turbo are you using? That would determine what you "should" be boosting.
Maybe carbon deposits are sealing the breach...If thats the case, I wouldn't depend on that as a permanent solution.
Old 03-10-2007, 09:12 PM   #9 (permalink)
i based what the boosting pressure should be by the ext wastegate spring, which is rated at 10psi. im using the greddy TDO6. for carbon deposits go, i just cleaned both surfaces and the gasket is new. the intense leak that there was before i was able to feel by hand. when i put it pack on the car after the new gasket and cleaning the surfaces, i stil felt a slight leak and when i drove it, the car boosted to 6-7 psi. after driving it, the leak was gone and the boost was at 10 psi.
Old 03-10-2007, 09:14 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
well, all sounds good now...
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Yes another turbo question MR2-Good-4-u MR2 Forum 10 03-03-2006 08:58 PM
Internal Wastegate?? robertsmb MR2 Forum 6 12-15-2005 07:47 AM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
3sgte fuel cut question MrJoe MR2 Forum 6 06-26-2005 10:53 PM
