Couple of problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2007, 02:06 PM   #1 (permalink)
Getting my dream on road
ryunosuke's Avatar
View ryunosuke's Photo Gallery
2nd Generation Couple of problems
hey guys few questions for my baby 1992 toyota MR2 2.2
#1. was driving the other day bout 80 mph for the distance of 30-35 miles and wen i came off the freeway my tempeture gauge went into the red zone .....recent changes were just got stock engine replaced with another, had the cluthch and flywheel replaced, water pump, and timing belt ,everything seems to be going fine till this day when it over heated, one thing i have noctice is that im not sure if my cooling fans are tunrning on they dont have any blockage or anything now does anyone have any suggestion on wat the problem could be? thermostat maybe??
#2. It seems that my shock on the back left is creeking and geting noise has anyone ever replace shocks or struts may someone help me with a detailed description of how to do so and also the best place to get the best price ?
thank you much hope to here from you soon
ryunosuke is offline   Reply With Quote
Old 03-09-2007, 02:21 PM   #2 (permalink)
Wasnt Me!!
View deuce93t's Photo Gallery
i had the same problem with my 93 NA well, when it was NA there could be a couple of things one thing that i noticed is that when you had all of that stuff replaced what might have happend is that you got an air bubble stuck in the cooling system and when you get the car going after a little while that air bubble is the cooling system gathers steam and then wilkl sit on the thermostate and makeing it seem as if you are running way to hot. it is easily fixed by having a local shop redo the cooling system the suck everything out and make it air tight and refill the system its no big deal the other is like you said it could be a bad or old thermostate. I would as well check the fans becuase if they arent running while you are idleing then you could have a over heating problem that way so i would check that first and then get into replacing the thermostate and getting the cooling system checked over! as for the shocks my buddy and i did mine but i would get them off of ebay get the KYB AGX which is what i have and i love them and just have a shop do them it is alot less hassel and time to have them do it. less down time on the car. Good luck i hope i helped
deuce93t is offline   Reply With Quote
Old 03-09-2007, 06:42 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
as deuce said, all the air needs to be evacuated from the system, or you will have heating issues..Does your heater work? If the heater core is not purged of air, it will not get hot. thats a sign to look for..Purge valve is under the frunk in the center. It's white plastic with flathead screwdriver groove..
Bleeding the MR2 cooloing system takes time and patience. There's so much piping running from front to back. Need to purge radiator too from **** at right top corner.
Thermostat could be malfunction too. As far as the fans, crank it up and listen to hear if the fans kick on.
Changing struts is a hassle . You will need a spring compressor. it's not that hard, but look out. if a spring breaks loose from the compressor, it can take your head off! I would take it somewhere and bring your own struts. I got 4 way adjustable KYB AGX for $290.00/set of 4 from Ebay. Labor for install will run about $400.00...
The Jedi Speeder at CarDomain
Old 03-10-2007, 05:49 PM   #4 (permalink)
ryunosuke's Avatar
2nd Generation thank you guyz
cool cool thank you guyz so much for the help hopefully it will get fixed very easy i wanna drive my baby like normal again
Old 03-11-2007, 08:54 AM   #5 (permalink)
Owns first Mr2!!!!!
View DjJester88's Photo Gallery
Similar problem happen to my Mr2 a few months back, so what I did was grab a oven mit, and a towel, put it over the radiator cap, and opened it, it let all this pressure out, that the towel was blown to the side, no mess though, thank god haha, but yeah, I let all the air out, filled the resovoir back up with 50/50 and drove it like half a mile, and the temp. meter will still go up, stop, and then it will go down.
DjJester88 is offline   Reply With Quote
Old 03-12-2007, 04:02 PM   #6 (permalink)
Young At Heart
View Zz_005_zZ's Photo Gallery
hmm
I will also say bubbles, or the thermostat... but thermostat could be narrowed down pretty easily.
Zz_005_zZ is offline   Reply With Quote
Problems Problems Problems Venom_5 3rd & 4th Generation (1992–1996 & 1997–2001) 17 05-26-2007 02:25 AM
98 Camry Starting Problems geomac 3rd & 4th Generation (1992–1996 & 1997–2001) 3 09-20-2005 06:36 PM
problems problems problems... robehsi Camry & Solara Lounge 4 02-13-2005 02:43 AM
1999 Camry problems nonstop only 28,800mi neuspeed 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-04-2004 12:03 AM
Defective LS430 safety problems. ls430-defect General Lexus Discussion 4 09-03-2002 09:44 PM
