4AGZE Losing boost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2007, 12:57 PM   #1 (permalink)
View VBAE92GTZ's Photo Gallery
4AGZE Losing boost
I put the ZE engine in about 2 years ago, and put a HKS pulley on it. It had about 30k miles on it. It boosted at about 11-12 psi, but now its between 8-9 psi. With about 50k miles on it. Ive tighten and replaced belts, checked couplings and clamps, and replaced the S/C oil. Whats the life of the S/C? Is this a common problem? Or is there something I'm missing?
VBAE92GTZ is offline   Reply With Quote
Old 03-11-2007, 09:27 PM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i'm not sure exactly, but i would begin to suspect the ABV itself. i have had the same problem, and i am chasing-down the same demon currently. luckily i have an extra SC. and i also have other projects to finish, so i will post on my dismally slow progress.
ToyotaTechGeek is offline   Reply With Quote
Old 03-13-2007, 11:40 AM   #3 (permalink)
also, try powering your ecu down for an hour. see if a reset does anything.
Old 03-13-2007, 04:02 PM   #4 (permalink)
Its not running off the stock ECU. And its not run off manifold pressure. Its on a programmable TPS. I hope its something stupid and easy to fix. The supercharger on the AE92 setups are a mofo to remove.
Old 03-13-2007, 05:55 PM   #5 (permalink)
Gameroom cash: $134355
yikes... running alpha-n on a gze with a manifold.... weird
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
silver top part numbers 91gtssilvertop Archived Corolla threads 19 11-03-2006 10:07 PM
losing boost in my gze waxer52 Archived Corolla threads 2 02-28-2006 12:47 PM
Problem with boost decrease Dragons88Supra Supra Forum 15 05-09-2005 10:35 PM
