Originally Posted by pinoyboi2006
ok so your saying that the turbo timer wont kick in if it senses that ders no need for it to turn on.
No, let it run when you think it needs to. Like when you've been running the car fast. Such as just getting off the freeway. If you just went to the store and never went over 40mph, then there's no need for a cool down. Just turn it off.
The idea is that you let the engine idle for a couple of minutes till the turbo cools down. The turbo timer turns off your car so you don't have to sit there while it's idleing. If the turbo is real hot from running hard and you just turn off the engine without a cool down, the oil in the bearings will literally fry. After this happens time and time again, it shortens bearing life. So essentially, letting the turbo cooldown before shutting off the engine will lengthen turbo life.
